  • 1994 - 1995 Specific Tech
Computer Recalibration?
  • Thread starter Thread starter wingnut1192000
  • Start date Start date Nov 14, 2004
W
wingnut1192000
14
  • Nov 14, 2004
We are having a lot of problems with our idle surging....to the point that it is stalling. We have read just about everything in this forum (very helpful, by the way) and we are now considering recalibrating the computer. How does one go about doing this? It is a 95 Ford Mustang GT with many modifications. Help?
TrueBlue95GT
966
Connecticut
Nov 14, 2004
  • Nov 14, 2004
The only way to do anything about the computer is to either get a chip or an eec tuner like the tweecer or PMS. You can't recalibrate our computer.
W
wingnut1192000
14
  • Nov 15, 2004
Thanks! Do you know anything about the motorvator chip? Is the Tweecer or PMS better?
RIO5.0
6,892
N.H.
Nov 15, 2004
  • Nov 15, 2004
I just had a car dyno tuned with a Superchip....Very impressive..came out with 80 more RWHP then we went in with...399.99 for the dyno time and chip..
read this months 5.0, an article called "fine tuning"....this software can do some amazing stuff...i witnessed it first hand.....
nothing against the Tweecer as I almost went that route...but there is a learning curve....for 400.00 it can be a done deal with a chip, since it reads like your modded and ready for a final tune....
the guys i went to know Fords, and that made a big dif....they mentioned they have there fare share of cars come in not running...soon as they hooked in the EEC they can see this problems...
Im sold on the chip, would love to spend a week with these guys, its amazing what they can do....
Did you do the complete idle set-up from scratch???
W
wingnut1192000
14
  • Nov 15, 2004
Thanks for the info, we will definately look into it. I will let you know. And yes, we did the idle set up from scratch. At this point, it is driving us crazy because we have tried everything and we cannot get the car running properly. We have a GTech in the car and it is telling us that we are doing the 1/4 mile in 13.57 at 106 MPH. That is crazy considering everything that is done to this car. We were hoping that maybe the GTech is wrong, but the car is running horrible! Thanks again for the advice.
RIO5.0
6,892
N.H.
Nov 15, 2004
  • Nov 15, 2004
Whats going on with the car??? what'd you add??? no sig..
W
wingnut1192000
14
  • Nov 15, 2004
The car is surging really badly to the point of stalling. I have replaced everything in the car! I have put the 345 hp ford racing engine, 30 lb injectors, 75mm maf cold air induction, 70mm throttle body, 410 gears, flow master cat back exhaust with off road h pipe, new tps, new iac and rpm jr upper and lower intake. I thought maybe it was electrical because it stalls if you turn the steering wheel at an idle or if you press the window button, but it doesn't seem to be a ground either. I was thinking that maybe the computer is causing the problem because of so many mods done to the car.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 15, 2004
  • Nov 15, 2004
You have several things going on that most likely is causing the t4m0 to go nuts.
The maf is caled for the 30lb inj's I would assume. If that is the case then your load reference point at idle has moved (which hoses with the fuel & spark tables btw) but the maf is trying to meter air with the cheat method and the whole thing at idle is just totally screwed. With 24lb inj's the error at small pulse widths is not so bad that you can, most of the time, get by but with those 30's the small pulse width conditions just dump too much fuel.
The cai setup can hose with low airflow (idle conditions) and cause trouble as well. I changed mine to a straight shot by removing a 90 degree bend in the fender and had to tweec the inj & maf values a bit to get back my steady idle after the cai change.
Your new combo is now pulling so much more air at idle due to the new parts but the values in the pcm are still expecting the amount of air that a stock 302 would use.
You can self tune with various tuning interfaces or get a chip but IMHO based on my findings with the t4m0 I don't think you can expect your pcm to LEARN its way around all of your changes.
My car would barely idle, stall a stop signs, idle way too rich, surge at low speeds, buck at cruising speeds, and all of the other stuff I'd be willing to bet you are dealing with at this time. I finally moved from the t4m0 (GT cal file) to the j4j1 (Cobra cal file) which is a better place to start tuning from due to it having values already in place for larger inj's, heads, cam, and the like.
Later
Grady
W
wingnut1192000
14
  • Nov 15, 2004
Okay well it seems like you experienced everything that I have and it definately sounds like you are on to something except that I don't know what some of your acronyms mean. :0) What is t4m0 (GT cal file) to the j4j1 (Cobra cal file)?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 15, 2004
#10
  • Nov 15, 2004
  • #10
The 94-95 Mustang GT & Cobra uses a pcm (powertrain control module) or computer that is from the same family. The hardware is the same but the calibration file or cal file is different. The GT uses the t4m0 file and the Cobra uses the j4j1 file.
In the other post I told you that I moved to the j4j1.
To make things more understandable I should say that I loaded the cal file that comes in the Cobra pcm into my original GT pcm which basically makes my 95GT pcm the same pcm that is in a 95 Cobra.
Hope that helps!
Later
Grady
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 15, 2004
#11
  • Nov 15, 2004
  • #11
In other words your computer really hates you and wants to be dyno tuned like NOW. By the way those motors come with the B or E cam which the 94/95 computer really hates.
W
wingnut1192000
14
#12
  • Nov 15, 2004
  • #12
Thanks for your help on this.....next question? How do I go about getting the j1j4 file and loading it and what can be done about my b303 cam? Also, I live in Jersey but am willing to travel to find someone that can dyno tune my car correctly as there is no one in this area. Any ideas?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Nov 15, 2004
#13
  • Nov 15, 2004
  • #13
They are in your area(Vineland to be exact) and use a mustang dyno http://www.thinkfastmotorsports.com/
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 15, 2004
#14
  • Nov 15, 2004
  • #14
There you go
Good thing about Stangs is you don't have to look too hard for help
Later
Grady
W
wingnut1192000
14
#15
  • Nov 15, 2004
  • #15
thanks will call them tomarrow and set an appointment appreciate info .
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
J
Access to Resources section of site?
  • jruhnke
  • Sep 16, 2025
  • Feedback Area | Testing Zone
Feedback Area | Testing Zone Sep 16, 2025
jruhnke
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
