Control arm removal
  • Thread starter Thread starter 95stocker
  • Start date Start date Apr 28, 2004
95stocker
236
Rochester
Apr 28, 2004
  • Apr 28, 2004
I've been fighting the old control arm bolts for 2 nights now and have had no luck getting any of them off. I don't have any air tools so that makes it like 10 times harder. I'm going to buy some liquid wrench and a new can of WD-40 tonight and let it sit on there for a few hours before I try taking them off again. Any suggestions as to how to get these things off???? I'm using a 1/2 drive and a sledgehammer right now, and it's not working at all.
R
rdksek844
300
Port St. Lucie, FL
Apr 28, 2004
  • Apr 28, 2004
Mine were extreemly hard to break loose. They were not rusted, they were just really tight. I had to use a motorcycle strut bar as a breaker bar just to break them loose, and it's amazing my 3/8" drive ratchet diddn't snap in half.
89roadster
1,124
Kent Island, MD
Apr 28, 2004
  • Apr 28, 2004
1/2" breaker bar extended with a 3+ foot of metal pipe over the handle
95stocker
236
Rochester
Apr 28, 2004
  • Apr 28, 2004
Yea mine aren't rusted either. Like you said, just really tight. I'm about 5 new cuss words from putting a new air compressor and tools on the ol' sears card.
95stocker
236
Rochester
Apr 28, 2004
  • Apr 28, 2004
how do you get all that under the car!?!?!?!?!?!?!?
I think I'm going to have to invest in deepwell metric sockets as well. (never had any use for them before now)
shawnster
78
Akron, Ohio
Apr 28, 2004
  • Apr 28, 2004
I had to deal with the evil control bolts last weekend and I never did get them out..I cut the control arm in half!! I was installing a rear end though and put new bbk control arms on..BTW..if you decide to cut them with a sawzall..be prepared to spend about an hour for each bolt and 5 sawzall blades for each bolt, the bolts are 10.9 grade and harder then hell..Good luck!
85GTlover
704
  • Apr 28, 2004
He is assuming your car is on a lift or blocked up well off th ground. I have mine jacked up with the stands on blocks. Must be careful but it helps to be high as possible. Yes "high as possible" whatever you get out of it.
79dog
1,046
Sunny Fl.
Apr 28, 2004
  • Apr 28, 2004
Wow, on my ol' 79 they weren't that bad. You are putting a wrench on the opposite side right? I just moved it till the wrench became lodged against the frame and used leg power on the breaker bar. Be careful though, make sure the car don't come off the stands.
dastang2
2,020
tx
Apr 28, 2004
  • Apr 28, 2004
cutting torch for me and then replace with new grade 8's.
H
horseplay91
283
Lake in the Hills, IL.
Apr 28, 2004
#10
  • Apr 28, 2004
  • #10
i just did all this recently and encountered the same problems
what i did was just use the breaker bar and jacked it up with the floor jack. worked pretty good. also you might want to break the bolts loose from the bolt side and not the nut so that the bolt will break free from within the bushing, otherwise you may find that the bolt itselt will be siezed inside the bushing after you take the nut off.
goodluck, Don.
Rick 91GT
Mustang Master
95
99
PA
Apr 28, 2004
#11
  • Apr 28, 2004
  • #11
Soak them with liquid wrench or PB blaster, let them sit then use a breaker bar as mentioned.
Then if they do not come loose use some heat, propane torch, etc...
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • dan50
  • Jul 18, 2026
dan50
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Front control arms
  • Bronco Bart
  • Dec 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2025
limp
