control arms
  • Thread starter Thread starter frmus3
  • Start date Start date Sep 17, 2004
F
frmus3
Banned
Sep 2, 2004
39
  • Sep 17, 2004
i bought tranny mounts motor mounts and upper and lower control arms for my 89 5.0 lx. I already put on tranny today and motors don't look too hard but those control arms look quite complicated. has anyone done this and do you have any advice on how to do it. for example when i did tranny mounts i need a jack under tranny to lift it up.
M
Matts89LX5.0
1,314
Long Island, NY
Sep 17, 2004
  • Sep 17, 2004
just unbolt the control arm and let the spring come out. then when you're putting the new one in, bolt the arm to the torque box first, then set up the spring on the control arm, and jack up the control arm till it meets up with the rear and bolt it in. Good luck
T
t-top 87
23
  • Sep 17, 2004
Make sure when you torque the rear control arm bolts the suspension is loaded, by placing jackstands under the rear. Good Luck.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 17, 2004
  • Sep 17, 2004
I wouldn't advise just unbolting a loaded controll arm. Jack up the car, put jackstands under the rear subframes and then let the rear axel hang. Unbolt the quads, shocks, and remove the swaybar. Use the jack and put it on the far end of one side and jack it as far as you and then the spring on the other side should just fall out. Do the same to the oppisite side. Then just unbolt the controll arms one side at a time. You can do two at a time but then the axel tends to shift around. Hand tight the new controll arms in and then do the same to the other side, install reverse of removal, your set.
Here's a tip, if it looks too hard, put on a blindfold or turn out the lights out to make it go easier. I did my HPM's which are more complicated at night durring a power outage, I had a candle, but it didn't help much.
D
Daggar
3,902
  • Sep 17, 2004
Ummmm.... sure it was a control arm you were handling there in the dark!
1968 coupe global west upper control arm template
  • Butchd88
  • Feb 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 12, 2026
Butchd88
R
Rear Upper Control Arm Pivot Point
  • Rcdgl
  • May 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2025
Rcdgl
R
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
28"x9" tire clearance
  • Sparky714
  • Jun 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2025
Sparky714
C
1965 Mustang Lower Control Arm Question.
  • chopper1876
  • Nov 9, 2024
1965 - 1973 Classic Mustangs -General/Talk- Dec 7, 2024
GOvert
G
