Until your one of the dozens upon dozens of efi problem threads5ive.oh said:Stay with the EFI, it's better on fuel and more driveable than a carb setup. But all it takes is a new intake and a carb, low pressure fuel pump, and a bit of messing with the vacuum lines. Of course the EEC IV will hate you.
http://www.jason.fletcher.net/tech/efi-carb/efi-carb.htm
oh there always broke, read a few forums.5ive.oh said:But if it ain't broke, don't fix it.
sbftech said:oh there always broke, read a few forums.![]()
While your figuring out your koeo codes, surging idles, replacing this sesor, that sensor, chasing gremlins I continue to drive right on by. Ya you get 3mpg better, big deal, I will trade that any day. To each his ownI don't have any problems with my EFI. For some, it's just too technical for them to work on. For me, it's very simple stuff really.sbftech said:you guys crack me up, people act like carbs cant be on a daily driverWhile your figuring out your koeo codes, surging idles, replacing this sesor, that sensor, chasing gremlins I continue to drive right on by. Ya you get 3mpg better, big deal, I will trade that any day. To each his own
You crack me up.
jrichker said:I seriously doubt that there are more than a handful of people here that can accurately & completely explain how many flow circuits are in a carb and how they work. Simplicity is an illusion...
jrichker said:Once again, why?
Carbs are great for the track and make good power. For a strip only N/A car, they are hard to beat. Step on the pedal and flush - it's a gasoline toilet!
EFI RULES on the street for a car that is driven in all kinds of weather, up and down mountains and gets great gas mileage. EFI will make just as much power as a carb and be easier to drive on the street. If isn't hard to tune if you know what you are doing.
There isn't a carb made without computer assist that can do all those things as well as EFI can. The only possible exception would be the IDA or DCOE Webers which cost major $$$ - like $3000 for 4 each IDA 48's and a manifold.
Here's a book that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by Charles Probst: ISBN 0-8376-0301-3.
It's about $20 from Borders.com see http://www.amazon.com/ . Select boo...ra charge. See [url]http://www.amazonhose.com for more information.
While you are at the electrical part, you'll need a Durspark or similar ignition system. The EFI ignition depends on the EFI sensors to advance the spark. Rip out the TPS and MAP/Baro sensors and the computer will have no idea of the proper ignition timing for best performance. Running a fixed timing setting is only for test purposes or for a race track only car. Don't try it on the street: the results will not be nearly as good as a properly setup Durspark or equal. Crane makes a really nice distributor for non-EFI applications. . See http://www.cranecams.com/index.php?show=browseParts&lvl=4&prt=127 for more information.
90mustangGT said:Carbs are simple, cheaper, and when set up right tend to run better. Carb cars do tend to make more power. .
90mustangGT said:Why do they call tuners, tuners... and why do they hog dyno shops and always have graphs instead of timeslips? because they are constantly tuning, and on the dyno while the hotrodders are out racing.
www.fordfuelinjection.com said:The question always come up: why fuel injection, and why Ford’s fuel injection?
But most answers start debates and holy wars, so lets look at a realistic factual answer. Performance: The stock 5.0L engine produced 250HP/300ft/lbs, and still passed emission testing. Cost: Ford EFI systems can be had at 1/3 the cost of aftermarket EFI systems. Peace of mind: not many fathers buy undependable cars for their daughters, so why should you drive one? Many people claim they can rebuild a carb on the side of the road. Current EFI engines can run 100,000 miles before needing a tune ups. Technology: Ford is leading other manufacturers in EFI technology development; they have spent millions of dollars making sure this was the ideal system. No other system in its class has its capabilities. It can operate upside-down, even if your oil pump can’t. It will never suffer from vapor lock. Hundreds of aftermarket vendors have products available for Ford’s EFI, and your closest parts stores have parts and support in stock. Understand I didn’t say it’s the best in the world, but it can be proven better than most.
