Convertable rear view mirror lights won't shut off
nrdu
A few days ago the lights on my rear view mirror stopped shutting off. I think I hit a bump to hard. :lol:
The only way I can shut them off is if I put the switch right in the middle of the off/on position (very hard to do). Also It seams like after a while the car will shut them off for me after I shut off the engine. I've started the car in the morning sometimes and the light will come on till I play with the switches again.
So, do I need a whole new rear view mirror or can this be fixed?
I missed the year. A 94-95 will shut the light off after a little bit.
I agree with the above - dont forget the dimmer switch too. If it's a door pin switch, they're 5 bucks at AZ.
Good luck.
lover said:
God I miss my rearview mirror. 2 12' Comp Kickers and a big @$$ amp = rearview mirror saying the hell with this, i'm out....:nonono:
LMFAO!!! :lol: (I'm laughing with you... not at you.... I swear! :P) Sounds like a nice amp though! :)
nrdu said:
Hrmm, how could I tell if it's the door switch? The door alarm shuts off when I close the door.
BTW, this is a 95 Cobra Convertable (if it matters).
I'd check the dimmer.
Those switches are independent from the dimmer and the door switches, I put a convrt mirror in my hatch because I never liked the light in the headliner. They have continuous power, problem is in the switches, unplug and remove the mirror the switches should pop out, try cleaning them,
