Convertible 1/4 Glass Problems
  • Thread starter Thread starter lgbnaf7
  • Start date Start date Aug 15, 2006
L
lgbnaf7
61
Tacoma Wa
Aug 15, 2006
  • Aug 15, 2006
I have a 86 Convertible. The front windows go up and down fine. I can't get the rear windows to bulge. I tried a extra motor and everything and still nothing. It seems like there is no power going to them. Is there some kind of relays I could check to make them work. Any suggestin is appreciated. Thanks
Henceforward
The Avatar Master
485
  • Aug 15, 2006
You can use voltage tester to see if there is a current.
Maybe both motors are burnt?
A rebuilt motor from NAPA is upwards of $70 so make sure you know it is dead before you buy a rebuilt one.
I ended up buying 2 new 1/4 window motors, plus a convertible motor.
Not cheap, but they work, and the dorky shark fins go down now...
HISSIN50
34
129
Aug 15, 2006
  • Aug 15, 2006
Hence is right-on. If it's lke an aero fox, once you pull the 1/4 trim panel aside, you can see the motor and it's E-connector. Disconnect the connector and put your test light/meter on the prongs from the body and press the switch both ways.
Good luck.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 15, 2006
  • Aug 15, 2006
you can buy them at autozone now, and their a easy rebuild
HISSIN50
34
129
Aug 15, 2006
  • Aug 15, 2006
Billison, where do you get parts? I need to rebuilt two motors and havent looked yet (I could use bushings and definately the capturing race).
billison
I like tinted tail
2,607
1,094
184
stl
Aug 15, 2006
  • Aug 15, 2006
man, it's been a long time since i did one, i was still in high school, i found some stuff at autozone for like 20 bucks, let me try and remember and look around,
billison
I like tinted tail
2,607
1,094
184
stl
Aug 15, 2006
  • Aug 15, 2006
http://cgi.ebay.com/ebaymotors/79-9...air-Kit-2_W0QQitemZ250015691519QQcmdZViewItem
1 cent on ebay
HISSIN50
34
129
Aug 16, 2006
  • Aug 16, 2006
1 cent on ebay
Thanks. I was aware of bushings - do those fit vert rear window motors too? I thought I remembered someone saying that they didnt (for the price, I'd try it anyhow).
How about getting the race that sits under the bushings? Have you needed to source those?
PuterAmI
513
Madison, Alabama
Aug 16, 2006
  • Aug 16, 2006
I don't know if those work, but 50Resto says these do.
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-WLK52 1&comp=LRS
Please remember that one bad switch in the rear ciruit, or a bad LOCKOUT switch could cause the same problem. Before buying motors, check the voltage at the connector as mentioned above. I first take off the cover and pull the switch and test there for voltage before pulling the panel just to see. If it's not there, it won't be at the motor, either.
Brushes are the most common to go on these. They use a copper braid to attach and the braid breaks at the brush. I found a set of brushes for an alterantor at Autozone that worked, but I had to cut them down a bit with sandpaper. Not a problem, but 50Resto now sells the brush kit for front or rear motors.
Grrrr.... I can't find them on their website anymore.
billison
I like tinted tail
2,607
1,094
184
stl
Aug 16, 2006
#10
  • Aug 16, 2006
  • #10
what i remember cleaning eveything and putting the bushings in and new grease, it's been like 7 years, sorry i'm not more help
HISSIN50
34
129
Aug 16, 2006
#11
  • Aug 16, 2006
  • #11
Thanks for the replies guys.
Puter - don't feel bad. I cant ever get LRS's search engine to work correctly - I have to hit the paper catalog to find what I'm lookin for.
Billison, thanks again. I figure there's about 2 dollars worth of parts in those motors that fail often (bushings, race and brushes). Too bad no one will make a little rebuild kit.
Coupe Rear Glass Cost
  • AeroCoupe
  • Jan 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
AeroCoupe
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
