SN95 Convertible Down. Quarter Glass Up. Why?
Yep what he said. I always say to myself there goes another vert with nonworking quarter windows. LOL
The sad part is that they are sooo easy to fix.
If it is the window motor, they are very easy to replace.. Just loosen the rear kick panel by removing the front screws. Remove the speaker so you have access. Pull back the kick panel and the motor is held in with 3 bolts and then unplug the power wire. Put some grease on the gears for the new motor and spray some white grease on the window guide and bushings.
I prefer to get my window motors from the JY as they are OEM and are only $10, and much better quality than the cheap Chinese made ones. I replace the plastic nubs in the motor with three 1/4 x 20 nuts, as the plastic nubs wear down over time and cause the window to stick. Repack the window motor with grease.
Install the new motor and test the motor. Then button everything up.
