  • SN95 4.6L Mustang Tech
Convertible Guys, how about this?
  • Thread starter Thread starter 94DanStang
  • Start date Start date May 14, 2004
94DanStang
31
  • May 14, 2004
Ok - so I was walking to my car one day after bowling, and I hit the auto trunk button and the trunk opened. I hit the unlock button and the door unlocks. What I couldn't find was the auto top button. Does anyone know of a kit that will let us automatically pop the top on our verts without being in the car? Maybe it would use something like those auto door poppers the hot rodders use...I don't know, I just thought it would be cool. Let me know what you guys think. Thanks!
Go HoTO!
602
Mountaintop, PA
May 14, 2004
  • May 14, 2004
Hey, anything is possible. You would need to unlatch the top, though, besides just running the motor. Moving the top up and down with a remote would be simple.
04DarkShadowGT
474
Fort Wayne, IN
May 14, 2004
  • May 14, 2004
i dont have a vert but arent there latches you have to unlock before hitting the button? I think that would be the only obstacle because I know people have alarms and stuff that lower windows/moonroofs/etc.
damacman
529
Phoenix, AZ
May 14, 2004
  • May 14, 2004
I have exactly what you're looking for. Basically, it's a Twindows universal window roll-up module that was designed to interface with one power window. It raised it when you armed your alarm and could lower it when you activated an auxiliary channel of your alarm. [Took two for a pair of windows.] An accessory for this module was the HCA-1 High Current Adapter that was designed to raise / lower the rear glass of the old K-5 blazers, Toyota 4-runners, etc. as they drew substantially more current than a power window motor. It also worked with convertible tops. I had this module on my 1988 Mustang GT convertible and it worked fine. You'll need someway to trigger it, so you're more than likely have to invest in an aftermarket alarm.
What will you trade me for it?
T
tacswa3
  • May 14, 2004
That is cool but I think the latches will be a problem. Anything is possible though.
94DanStang
31
  • May 14, 2004
Yeah - that is the stumbling block, how to unlatch the top. I figured it would be easy to start the car and power the top down. Just those darn latches.
damacman
529
Phoenix, AZ
May 14, 2004
  • May 14, 2004
btw, I have both the module and the HCA-1 High Current Adapter -- you'd never find one otherwise . . .
damacman
529
Phoenix, AZ
May 15, 2004
  • May 15, 2004
guess Dan lost interest in this . . .
AJ99MustangGT
218
Fenway Park
May 15, 2004
  • May 15, 2004
I dont think he lost interest... im interested too, but your module isnt any good if we cant figure out a way to pop the latches located above the sun viosrs on the drivers and passengers side. Those things require a decent amount of force to pull oven, so some sort of mechanical device will need to be developed to force it open.
damacman
529
Phoenix, AZ
May 15, 2004
#10
  • May 15, 2004
  • #10
I typically left the top of my '88 unlatched so that I could open / close it from the remote control. I also had Clifford SmartWindows II modules on both the front and rear windows. The whole system was pretty slick -- arm the alarm and the front windows closed, then the rear windows closed, finally the top closed. Since this took about 20 seconds to complete, the system would also bypass all of the sensors to eliminate the top triggering the alarm. Disarm, and within 10 seconds press the aux channel and the front windows lowered, then the rear windows lowered, then the top. If you're worried about making it easier for a thief to get in your car, then just realize that they'll cut the top before they try the door handle. I installed some micro magnetic reed switches on both sides of the top part of the windshield frame that would trigger the alarm if the top was pulled back.
If you were REALLY ambitious, then you could set up some pneumatic solenoids to open / close the latches. In my opinion, this would certainly not be worth the effort. btw . . . I still have a pair of SmartWindows II modules with harnesses too . . .
M
Too much for me to repair in my current housing situation
  • My Drama Magnet 04 Gt
  • Apr 1, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 14, 2026
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
94 5.0 gt convertible trunk relay box
  • DeanS
  • Aug 12, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 13, 2024
WhiteCobra95
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
