  • Mustang Sound & Shine All
Convertible sound setup 99-04
  • Thread starter Thread starter 04ShadowGT
  • Start date Start date May 18, 2004
04ShadowGT
112
Elizabethtown, KY
May 18, 2004
  • May 18, 2004
What does everyone have in their 99-04 vert? Any suggestions? Looking to keep stock Mach 460 system and just add bass in the trunk with perhaps, 1 12", 1 10" or 2 10". Whaddya think?
Barjam
38
  • May 19, 2004
I am thinking about taking the back speakers out and replacing them with custom fiberglass enclosures that will hold a pair of JL 6w0s (or 8s if I can get them to fit, doubtful). I am going to put a pair of alpine SPx-177as up front. As far as amps, probably a mono class D for the subs (mid level brand line alpine or something) and a nice 2 channel for the comps.
I haven't decided on the head unit, I like the idea of keeping that stock as to not draw attention to it. It depends on how much signal loss I have going through a line level converter.
If you don't mind loosing trunk space I would put a 10 or 12 in the back. Personally I want to keep the trunk space.
If you are going for SPL, my solution wouldn't be for you. I am more into SQ and I don't listen to much rap (and no hip hop).
P
Phoenix00GT
245
Bay Area, CA
May 19, 2004
  • May 19, 2004
My setup is listed below in my sig
M
macatak60
46
  • May 19, 2004
00 vert
i've got a 00 vert and i'm going to customize the back seat b/c i have a 50resto style bar and that basically eliminates anyone in the abck seast
i have a JVC El Kameleon head unit w/ the factory door speakers and i have 2 Infinity Kappa subs. I have a kenwood 425 watt amp and its' pumping great power to both 10s.
i'll keep ya updated on my box.....i plan on removing both seats, and i'm making a custom ice chest and storage compartment on the bottom and then i'm coming off the top and have my subs firing down to get maximum sound.....i'll post pics with each progression......though it will be a couple of weeks to a month to get the whole thing done
spectravp
424
NY
May 20, 2004
  • May 20, 2004
If you plan carefully enough, you can get a ton of stuff in your trunk and still have room for the boot. I have 3 10" JL Pro Audio 10w6's in a vacuum sealed box; negative 10 pounds. That allows you to make the box super small. Made it out of fiberglass and molded it in behind the rear quarter panels. I then have a sound field controller, 4 alpine amps, 4 crossovers for the Boston Acoustics components (6", 4" & Tweets; front & rear), 2 Farad caps, 12 disc changer, all phoenix gold interconnects, etc etc... it's all in my trunk and I can still fit the convertible boot. The only problem is the added weight over the rear wheels. I had to stiffen the suspension and then do some minor engine mods (cold air & chip) to bring it back to acceptable performance. An extra 400 lbs does a lot.
As far as the 8's in the rear, I had JL 8's in mine... I had to make a cusom bracket.. no biggie.. but one warning... make sure the braket clears the top mechanism. I made a boo boo myself. I ended up taking out the 8's as I found I needed more mid-high ranges when the top was down... the 3 10's have plenty of punch so the 8's came out and the BA 6" went in.
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech May 31, 2026
LILCBRA
