Convertible Top fluid..
93 LX
3,081
Norwalk, CA.
How can you tell if the system is full? How do you add fluid? Does the system need to be purged? The fluid if dark in color and it will not hold a position. I am trying to clean down in the well but when i set the top to the best position to get this done it either goes down all the way or will open all the way.
Thats a pretty good write up.
And that is how check and fill my convertible top pump. The only time that I have had to do anything with it is when I had to swap out the pump cause the brushes in mine went out. And just for info if your pump ever goes out Ford used the same pump in Mustangs from 1965-1993 and possibly in other cars as well during that time period.
