Convertible
  • Thread starter Thread starter Tom Newell
  • Start date Start date Jan 8, 2018
  • Tags Tags
    convertible
T
Tom Newell
  • Jan 8, 2018
Hi, my mustang is a 5L convertible that I have put a new top on, before I put the top on it was going up and would stop 4" from the top, after I put on the new top on again the top would stop at 4" from the top, i put fluid in it and it doesn't make any change. What should I do!!!!!! Tom
billison
I like tinted tail
2,607
1,094
184
stl
Jan 8, 2018
  • Jan 8, 2018
Hi tom.
I when you say you changed the top, do you mean you changed the fabric or you found a complete top with frame and all?
If you changed the fabric, you’ll want to grab a buddy or two , get the car is a warm/almost hit garage for a couple hours, then slowly push the top till it can close and latch and leave it a few days or weeks so it stretches out.
If you did the top with frame, one of the mounting points on the sides that looks like a sequels is actually a rectangle and can be installed upside down, this will cause the top to bind
T
Tom Newell
  • Jan 9, 2018
Hi, when I say I had a convertible top supplier put the top on, just the fabric. The problem is it did not change from the old to the new, it does not go to the top edge so I can fasten it. Tom
billison
I like tinted tail
2,607
1,094
184
stl
Jan 9, 2018
  • Jan 9, 2018
Ok, if you had the top professionally replaced, the top needs time to stretch. Get a buddy and push the top down and latch it and leave it a week.
General karthief
Mod Dude
Aug 25, 2016
28,118
10,736
213
polk county florida
Jan 9, 2018
  • Jan 9, 2018
https://lmr.com/item/LRS-8393GUIDE/1983-93-Mustang-Convertible-Top-Guide-Book
I suggest this guide for the diy convertible owners, I left mine in my vert when I sold it
I miss that car
And stangnet members get a discount from lmr
T
Tom Newell
  • Jan 9, 2018
The top won't allow for me latch it down, 4" short, it did this when I had the old one, around 5yrs ago and with the new one, two yrs ago.
billison
I like tinted tail
2,607
1,094
184
stl
Jan 9, 2018
  • Jan 9, 2018
Can you either better explain the issue or post
Pictures?
If it’s a new top, they are very tight when New, and very hard to shut and usually require more than
One person, once shut, it’ll slowly stretch.
T
Tom Newell
  • Jan 9, 2018
Hi, you are right, the top is too tight, it has been down for around 6 months. I'll get pictures.
billison
I like tinted tail
2,607
1,094
184
stl
Jan 9, 2018
  • Jan 9, 2018
Yup. That’s the issue then.
The easiest and safest way to will be something like this.
1. Get the car is a heated garage, crank the heat and let it set till the whole car is warm. “ optional but suggested”
2. Get 2 buddies, beer and pizza may be required.
3. With you on the inside and one guy on each
Side, run th pump till it goes as far as it will go, then with gh help of your pizza and beer fuel comrades, push and pull until you can close the top. Leave it this way at least a week.
4. Never store th car with the top down.
5. Tell the wife how you fixed it and saved yourself millions of dollars.
Reactions: BlakeusMaximus
General karthief
Mod Dude
Aug 25, 2016
28,118
10,736
213
polk county florida
Jan 9, 2018
#10
  • Jan 9, 2018
  • #10
I take it the top has never been latched?
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Tuesday at 10:55 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 1:54 PM
limp
Progress Thread Hello from Nashua, NH
  • sevenup
  • Oct 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
sevenup
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
