The TFS heads will flow better. Aside from that, I'm now sure what it is that you'd like to know. For cam recommendations, I'd always suggest a custom. You will need longer pushrods. Your pistons will dictate the limits for your new cam. Check out Trick Flow's website for the breakdown on the heads. It will tell you what the suggested max lift and duration is for stock pistons.
