  • 1994 - 1995 Specific Tech
Converting to a Carb'd Setup
  • Thread starter Thread starter k00ksta
  • Start date Start date Aug 23, 2010
k00ksta
158
Chicago
Aug 23, 2010
  • Aug 23, 2010
Anyone converted there setup to a carb'd setup? I am getting so damn tired of the computer in my SN95 that I am about ready to pull the top half out the car and just go carb'd. Getting chip's burnt is a pain and its not a daily driver so anyone think its a dumb move and I should just continue to fight with the damn thing to get my stroker setup to stay running right?
F
fordtech28
312
Riverside Cali.
Aug 23, 2010
  • Aug 23, 2010
it would just as expensive to convert it to carb with no big benefits if you get a tuner software like tweecer or quarterhorse you can keep tunning your car as you make changes to it mail order chips are not always dead on .
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 23, 2010
  • Aug 23, 2010
Swapping out that e cam would probably solve half your problems.
Kurt
hssnpny
49
SoCal
Aug 23, 2010
  • Aug 23, 2010
What's the downside of running an E? I don't doubt that there are better cams, but I don't have any driveability issues with mine.
Adam95GT
2,564
Burlington, NJ
Aug 24, 2010
  • Aug 24, 2010
EFI to Carb conversion- Mods Sticky please
But seriously... just tune the car.
Black95GTS
1,644
Marlborough, MA
Aug 24, 2010
  • Aug 24, 2010
E-cam was designed for a naturally aspirated, carb'd, 302, with stock heads.
You have a supercharged, fuel injected, 331, with Twisted Wedge heads.
Square peg --> round hole.
Adam
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 24, 2010
  • Aug 24, 2010
E-cam is just a really old single grind design. Cars tend to have tuneability problems with them, andit's not very good on the performance.
Kurt
k00ksta
158
Chicago
Aug 24, 2010
  • Aug 24, 2010
Kurt
What cam would you suggest? I am emissions exempt.
k00ksta
158
Chicago
Aug 24, 2010
  • Aug 24, 2010
Also anyone had decent luck with quarter horse? or have a used tweecer rt they wanna sell?
bayellowstang
462
Carlisle, PA
Aug 24, 2010
#10
  • Aug 24, 2010
  • #10
I have my car idling fairly decent with the X303 and a twEECer RT. I have never used the QH but it can log more parameters then the tweecer which is always better.
Adam95gt has a QH, don't know if he got it all working yet though.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 24, 2010
#11
  • Aug 24, 2010
  • #11
Sure E cam of fury is outdated
Then again
With mods such as those
You're gonna have to tune anyway
One way or the other ... You're gonna have to deal with it
Grady
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Aug 24, 2010
#12
  • Aug 24, 2010
  • #12
Cam selection comes up on this website all the time on this website. I've come to the conclusion that there really is no way I can give you anywhere near as valuable advice that you can get from a cam professional. If you call Comp Cams and speak to a tech there, you're going to get much better advice. They probably have the largest selection of off the shelf cams. Most of the people on this website recommend a custom cam, which is good advice, and only mildly more expensive than buying an off the shelf grind. If you want an off the shelf cam, I would call Comp, and Anderson. Maybe a few other places. I've driven a few cars with a milder head setup than you have, and an e cam. That cam is a dog, and is so outdated.
Kurt
C
cody50
29
I live in the frozen tundra of Bismarck ND
Sep 2, 2010
#13
  • Sep 2, 2010
  • #13
I went carb, because i went 427. The efi stuff really chokes down airflow on big c.i. I don't think you will have much problem feeding the 331. I would stay stick to the efi if it is a daily driver. Tuning is constant either way, and you will never get it perfect, only close. I had a comp .555 .565 hydro roller in my 347 I really liked. Lots of low end torque yet.
stangbangerrick
63
Colonial Hgts, VA
Sep 2, 2010
#14
  • Sep 2, 2010
  • #14
I have a 95 gt with a 331 stroker with a ford X303 cam and had it dyno tuned with a SCT chip. When I picked up the car it was great all issues with the hanging idle and engine cutting off went away and I had more power and torque. But after 2 months the car was cutting off after I would drive it and then turned off the engine and it sat lets say for more than 5 minute and I would go to start it it would die unless I gave it some gas and let it run fast for about a minute or if I would drive it right away and did not have to stop and after about 100 feet in would run and idle just great. I have changed the IAC, TPS, plug wires and check all the sensor, still the car is not running like it did when I picked it up from the tuner. Took out the chip and the car returned to it old self before I got the tune. Put back in chip and hooked up my friends LM1 unit to the car (had a bung put in the o/r x pipe for the wideband 02) and we did some runs set on all 3 tunes at WOT in 3rd gear and the A/F ratio was never less than 14.8 which is way to lean. Finally got ahold of the tuner and he tells me that the tune is good and something else must have gone bad. He said he would take a look at it but it would have to be after the 7th of Sep. I think I will be getting the moates quaterhorse and become a maste of my own tune.
stangbangerrick
63
Colonial Hgts, VA
Sep 2, 2010
#15
  • Sep 2, 2010
  • #15
Adam
Ford Racing Performance Parts catalog (2006) states "On EFI engines performance camshafts work only with mass air induction systems. Will not work with Explorer EEC-V EFI"
To say that they would not work on EFI that is running the mass air induction is false.
Black95GTS
1,644
Marlborough, MA
Sep 3, 2010
#16
  • Sep 3, 2010
  • #16
Where does it say in my comment that it won't work? Of course it will still run, it just performs like crap, especially in light of modern technology.
If you're going to fight the same tuning issues anyway (you are) then it might as well be for sizeable gain in the end. An e-cam is gonna get you... a lopey idle.
Adam
legalize420
1,541
South Florida
Sep 3, 2010
#17
  • Sep 3, 2010
  • #17
Adam
wow so if i change my cam i can pick up some major horsepower. you think i can break 300 with a tfs1? to think all that time the only thing it was good for is sound.
Black95GTS
1,644
Marlborough, MA
Sep 3, 2010
#18
  • Sep 3, 2010
  • #18
You won't break 300 because your heads won't support it naturally aspirated.
Adam
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Yesterday at 10:49 PM
phil2001svt
9
RECEIVED OFFER TO BY MY 92 LX CONVERTIBLE
  • 92StangGirl
  • Mar 23, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Mar 23, 2026
General karthief
