Converting To Fuel Injection
Old Skooler
248
43
39
Im converting my car back to fuel injection and looking at stand alone fuel systems. The PO ripped out all the wiring and harness so I'm basically starting from scratch. I've looked at the fast efi systems but I have no clue what's best. Cliff note version of the motor is a 347 AFR heads custom cam with the fuel injection will be a Novi 2500. Not sure of what intake to go with I'm leaning towards the Systemax.
Any input will help.
i would go with the megasquirt system, probably the mslll with an ignition controller. that way you can build your own system inexpensively, including the harness. the nice thing is that you can tune it to fit your combination. you can also add a flex fuel sensor and it will also work with E85 if you choose.
If you need anything for the wiring harness I have a donor car with complete harnesses. one from a 89 GT and one from a 90 GT and an extra A9L computer laying around. Sounds like you are going more for the custom side though.
Reactions: jrichker
