  • 2.3L (N/A & Turbo) Tech
Converting to side posts (battery)
  • Thread starter Thread starter 1992 2.3LX
  • Start date Start date Feb 1, 2004
1992 2.3LX
885
Ky
Feb 1, 2004
  • Feb 1, 2004
side posts are so much easier to use than the top posts. so to convert it do i just need the connectors?
Dr_EluSivE
2,155
Central Illinois
Feb 1, 2004
  • Feb 1, 2004
Side Posts Eaiser than top??? You are nuts!! But if you Really wanna make your life difficult, just swap the stock cables out for some side post cables of the same length and you are done.
Dr.
1992 2.3LX
885
Ky
Feb 1, 2004
  • Feb 1, 2004
i have them on my turck and i like them way better. just grab the 8mm wrench and go. no need to use the adjustablee. i think it looks a lot better as well.
Dr_EluSivE
2,155
Central Illinois
Feb 2, 2004
  • Feb 2, 2004
they are fine till they corrode under the connection (like most GM's do) or until you need a jumpstart or charge your battery. Then they suck. My friends Oldsmobile is Virtually impossible to jump, there is no space to put cable clips and if you can get it on, the only part that is grippable is small 8mm nut.
Dr.
1992 2.3LX
885
Ky
Feb 2, 2004
  • Feb 2, 2004
i just jump it on the alternator. i haven't had any corrosion problems and the old battery (side posts) has been in there for 7 years. now on my stang that's a different story.
is there anyway to stop corrosion. i'll clean it all up and 2 weeks later it will be back. so very annoying.
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
Installed xm radio shaker 1000
  • Rollback82
  • Jun 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 14, 2026
08shelby GT500
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
