  • 2005 - 2009 Specific Tech
Engine Cool fan and AC problems
  • Thread starter Thread starter JussRJ
  • Start date Start date Aug 16, 2019
J
JussRJ
Atlanta
Aug 16, 2019
  • Aug 16, 2019
I have a 2008 mustang and I’m having problems with my AC and fan.. My car runs hot after about 30min driving and I believe it’s due to the fan not kicking on. So I tested relays for the AC and high and low fan all is getting power. The fan sometimes comes on and and goes back off the same with compressor the compressor comes on and goes off within 2/3 second intervals. I noticed Also the top radiator hose doesn’t have pressure when the car overheats. Don’t know if this has anything to do with the problem seems electrical of some sort but the horn recently stopped working. It gets power when I run a connection straight from the battery but it doesn’t sound when I press the horn pad and the alarm chirp doesn’t work. I could press the panic button on remote and the lights flash but don’t sound. I replaced the clock spring and horn spring already problem still occurred. One day while raining the horn did work but only when the car sat still and once I turned the steering wheel it would stop again. I love my mustang but this is a headache.
Dino Dino Bambino
1,673
90
79
Cyprus
Aug 18, 2019
  • Aug 18, 2019
Sounds like you have two separate unrelated problems.
1. Check the fan relay terminals and the terminals inside the underhood fusebox to see if they're melted. If so, there's a short in the fan circuit and the likely source is a bad fan resistor.
2. Check the front passenger floor and the smart junction box for water contamination. The horn problem could be due to a blown fuse, corroded terminals inside the SJB, or a blown horn relay.
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
J
2007 No Heat or AC Control
  • JonScoupe
  • Jan 18, 2025
2005 - 2009 Specific Tech Jan 25, 2025
Resolved Electric fans
  • Serg.Xof
  • Jul 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
