  • SN95 4.6L Mustang Tech
Coolant change?
  • Thread starter Thread starter 93octane
  • Start date Start date Jul 21, 2004
9
93octane
46
  • Jul 21, 2004
I have an idea of how to change the coolant. Just need to know if I'll be doing it right.
1. Drain the radiator.
2. fill up with distill water
3. run engine and turn heater on.
4. drain radiator
5. to steps 1-4 until water comes out clean.
Now to re-fill. Should I mix the one gallon of anti-freeze with 1 gallon of water in one separte container and then pour the mix until I fill up the radiator??? Will this give me the 50/50 mix I need and what a happens to all the water trapped in the heater core?? I don't know how much water is trapped in there. That means I'll have a little more water than anti-freeze will I still have a 50/50 mix???? Any tips welcomed
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 21, 2004
  • Jul 21, 2004
i personally never use distilled water. ive been told my people from prestone that it is formulated to use tap water instead of distilled. if you want you can get a funnel and try to pour the water and coolant in at the same time. but it wont matter if you have a little more water than coolant or vice versa as long as its within a 60/40, 40/60 mixture.
J
johnnyboy1111
84
  • Jul 21, 2004
distilled water
I would go for the distilled water and the red anti-freeze , with a 50-50 mix done like you did .......I've read that when aluminium heads, blocks , radiators are used ....the red anti-freeze is needed...I have 100,000 plus and looking in everything looks A1...... I've been using distilled water for about 20 years on different cars and have found its much better, where you live in the US has a lot to do with how the water will affect the cooling system, Florida tap water will turn your tea pot white in about a week.......I rest my case !
YardSpecial
2,664
MT
Jul 21, 2004
  • Jul 21, 2004
Johnyboy is SO RIGHT !!
You never know the quality of the tap water.
In our house its super full of minerals and very hard.
Wal-Mart sells distilled very cheap...........
I pre-mix mine so to have a PERFECT 50/50 mix.(5 gal can)
I change mine every two years along with a NEW thermostat every time.
My water pumps last over 150K doing this and ZERO rust in the block !!
YardSpecial
2,664
MT
Jul 21, 2004
  • Jul 21, 2004
To answer Merc..............
Cause I no trust it...............
Me - stuburn mech. 25+ years..........
I like Prestone and Peak brands.........
Some say pre-mix is used Anti-freeze........
Good point Merc !!
( i have money to BURN also)
merc123
420
North GA
Jul 21, 2004
  • Jul 21, 2004
Why not buy the pre-mixed stuff? I mean it's a few $ more and it's never wrong (theoretically)
9
93octane
46
  • Jul 22, 2004
Should I buy 2 gallons of Prestone anti-freeze?? Mix 2 gallons of Anti-Freeze and 2 gallons of distilled water and premix in a 5 gallon container and fill the car radiator??? Sounds like a good plan to me.
YardSpecial
2,664
MT
Jul 22, 2004
  • Jul 22, 2004
Thats what I do bud !
I use a CLEAN 5 gal.kerosene can marke for 50/50 anti-freeze only !
Reason is I have 2 Stangs and 2 trucks.
twogts4us
4,188
12
79
Dunedin, FL
Jul 22, 2004
  • Jul 22, 2004
Yep, buy 2 gallons of Prestone and mix with water in a separate container, then add to the car. By the way, one point not made here is the fact that you need to get the nose of the car up to at least level if not higher to prevent air from becoming trapped in the system. You want the fill neck to be the highest point of the system so air trapped air will rise out of the neck. I fill the system, then put it up on ramps, remove the cap and top it off.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 22, 2004
#10
  • Jul 22, 2004
  • #10
YardSpecial
2,664
MT
Jul 22, 2004
#11
  • Jul 22, 2004
  • #11
Never had a problem with air, since the thermo has a hole in it.
The DOHC has big time air problems.......
Good advice tho !!
Red mustang Gt 46
601
Good ol' Maryland
Jul 22, 2004
#12
  • Jul 22, 2004
  • #12
When your done filling what you've got, you will have to purge any air in the cooling system (sealed cooling system). If you do not, the engine will run hot.
9
93octane
46
#13
  • Jul 22, 2004
  • #13
How do I purge any air in the cooling system??? My car is a 99 GT??? Will putting the car in an incline after filling purge the system. Or should I incline the car before filling it up???
Red mustang Gt 46
601
Good ol' Maryland
Jul 23, 2004
#14
  • Jul 23, 2004
  • #14
Sit in incline (radiator up) fill, 1. run until thermo opens, 2. let cool, fill, repeat 1&2 until full. Massaging the upper and lower hoses when cool speeds the process.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
