Coolant leak
  • Thread starter Thread starter BTits
  • Start date Start date Jun 21, 2005
BTits
  • Jun 21, 2005
I noticed coming home from work my Engine Temp gauge was creeping up to the red mark, but would keep bouncing down and up. When I got home, I opened up my hood and it smelled like coolant real bad. I checked under the car and I have a coolant leak coming from right behind the raidiator. Anyone have any clue what it could possibly be??
HISSIN50
34
129
Jun 21, 2005
  • Jun 21, 2005
I would carefully clean it up and start it and watch (BE real careful about the moving fan, serpentine belt, hot coolant etc). Coolant is very good at running down things, making it tough to find the source.
That said, when water pumps let go and start leaking through the weep hole, the fluid can run down the lower hose and fall onto the ground in the neighborhood of the radiator. I think you will just have to check it over.
Good luck.
P
PonyBoy90
555
Toronto
Jun 22, 2005
  • Jun 22, 2005
Your rad either has a hole in it, or the water pump is shot.
I think it's your pump though just based on where you said the leak was.
I'm assuming you checked all your rubber hoses for any cracks or splits?
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
