coolant leak
rockyracoon
874
27
49
margate NJ
it appears that im leaking freeze from between the timing cover and the block.I thought only oil could leak from there.It is not super bad but it is coming out and welling up on top of the cover in the little valley on each side,its not bad enough that any drips down onto the ground,plus it is evaporating on the hot housing cover. Every day I need to top off the reservoir.I replaced the timing chain last month and I used the gaskets provided with the kit,however I didnt use rtv,just the gaskets with some adhesive to hold em in place.But still I cant see how freeze can leak from there and not having a crankcase full of glycol.
it is probably comong from the intake gasket. it is actually pretty common for the corners of the intake gasket to leak on SB fords. be careful when you remove the corner intake bolts. odds are they are corroded and will snap off in the heads. use a little heat.
The bypass hose, the thermostat housing and the gasket between the block and timing cover, the timing cover to waterpump, and the plate on the back of the waterpump can all leak.
Sometimes a gentle tightening of the bolts will slow it up.
Best way to remove and replace the gaskets. I have had both gaskets and rtv work on the water pump.
The country boy would tighten the bolts and put in stop leak......
