Coolant Leak...
  • Thread starter Thread starter cperezsvp
  • Start date Start date Feb 14, 2010
First Prev 2 of 2
C
cperezsvp
18
Tinker AFB
Feb 15, 2010
#21
  • Feb 15, 2010
  • #21
here are some vids
http://www.youtube.com/watch?v=sfc8QudABu8
YouTube - leak idle2.MOV
YouTube - leak off.MOV
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Feb 15, 2010
#22
  • Feb 15, 2010
  • #22
That's a pretty big leak.
The drip is coming off the timing cover, but it's tough to say if it's the cover that's leaking or if it's dripping down from above.
I don't think it's the Water Pump that's leaking.
Just tough to see where it is. It's really kinda up to you. I suggest cleaning the hell out of the area with carb cleaner and then run it and see where it oozes from
C
cperezsvp
18
Tinker AFB
Feb 15, 2010
#23
  • Feb 15, 2010
  • #23
OK sounds good will do. I'm betting you guys are right though. i'll let ya'll know next weekend for sure though
fiveohwblow
Official Member
2,169
145
155
Feb 15, 2010
#24
  • Feb 15, 2010
  • #24
That timing cover is kind of a ***** but I am sure if you have even beginner mechanical skills you can do it. The biggest problem with them is the spot and the bottom where it meets up with the oil pan. In this instance, I am sure Mike and I agree. USE THE PIECES PROVIDED for the gaskets, not just silicon. Those also arent cheap and are made of aluminum so I would suggest pulling one from a car in a yard or from someone who pulled it themselves. Heard of these being warped or damaged second hand.
C
cperezsvp
18
Tinker AFB
Feb 16, 2010
#25
  • Feb 16, 2010
  • #25
hmm ok, i'll keep that in mind
C
cperezsvp
18
Tinker AFB
Feb 16, 2010
#26
  • Feb 16, 2010
  • #26
so i cleaned the area pretty good this afternoon, and tried to do a coolant test with a pump i rented from auto zone (which wouldn't seal... worthless); but it seems to be coming from the water pump on the lower right side - dripping. after awhile it starts to come out of the top, and it puddles up. Thats why i thought it was the lower intake manifold gasket. Lets hope i'm right let you know sat afternoon!
C
cperezsvp
18
Tinker AFB
Feb 20, 2010
#27
  • Feb 20, 2010
  • #27
so as promised i worked on the mustang today. i bought a new water pump because mine was horrible and got everything back together. Then noticed that the water pump NAPA sold me DIDN'T fit my water pump pulley!!! the plate the pulley bolts to on the NAPA pulley is smaller than my water pump!
C
cperezsvp
18
Tinker AFB
Mar 1, 2010
#28
  • Mar 1, 2010
  • #28
So to fix the previous problem i bought a set of Trick Flow underdrive pullies. But after it was all said and done I still LEAKED coolant!!! its comming from the timing chain cover. I'll be fixing that later this month.
M
Mike in Texas
121
#29
  • Mar 2, 2010
  • #29
I had a leak in the same spot, turned out to be the lower intake gasket. I found some good articles w pics (5.0 Mustang mag I think). I'd really suggest doing some research on the gasket change before jumping in. I'll check to see if I can find the web sites for you.
C
cperezsvp
18
Tinker AFB
Mar 2, 2010
#30
  • Mar 2, 2010
  • #30
ok sounds good! yeah i cleaned the area really good to see because i though it was from the lower intake manifold first. I looked in to changing the timing chain gasket, and found one that says you can remove the timing chain cover & gasket later if need to; with out removing the oil pan and oil pan gasket again. is any1 else using this gasket?
First Prev 2 of 2
Flushing water from the radiator and block.
  • djj62478
  • Oct 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
A
Overheating!
  • ashleyg
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
limp
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
