Coolant light is on.....?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
I've noticed that my coolant light comes on when I first start the car a lot of times. It never stays on, usually never on for more than five minutes, but I've also noticed that my car runs a little hot and on the temp. gauge the needle sometimes gets just about to the "A" in "NORMAL". I've read that this is normal for my car and that a 180* thermostat will clear it right up. But why is my coolant light coming on?
First thing - read the thread on Ford Factory Gauges. They are only "relative" gauges; not much better than idiot lights. As to your situation, I would drain your radiator and add fresh coolant. You may be running less than a 50%/50% mixture (you can check that with an anti-freeze tester - you want to have 4 - 5 balls floating). If you are less than that, you are probably boiling your coolant and boiling coolant is not a good heat conductor; hence your hot light coming on. Obviously check the coolant cold and change the coolant cold. Check for air pockets next day and top off. Good luck!
Well I just recently had to replace my intake manifold so all the coolant was replaced at the dealership. You think maybe they didn't mix it well enough? Also It only comes on when i first turn my car on, so the engine hasn't even heated up yet.....
Could be as simple as a defective sending unit on the replaced manifold. In any case, check your coolant with an anti-freeze tester and make sure you have 4 - 5 balls floating. They might have added watered-down anti-freeze. A new sending unit may solve your problem (on top to right of alternator).
Just get an all color, all make / model, 50/50 mix and top off your radiator...it should go away..
but if you dont know what type of coolant is in their then just flush it out and put some good collant in their.
