  • SN95 4.6L Mustang Tech
coolant light sometimes stays on
  • Thread starter Thread starter XtorT'r
  • Start date Start date Mar 9, 2007
XtorT'r
381
Minnesota, YAAA
Mar 9, 2007
  • Mar 9, 2007
Just like the title, Every now and again when I start my car the dummy light stays on for the coolant. My temp gauge seems ok and usually if you shut the car off and restart it goes off but it's a PITA and I figure I might be ignoring a bigger problem. Anyone have an idea what it might be. I've had the coolant changed regularly and I think last time I had the thermostat changed as well.
Maybe some sensor somewhere I can look at?
forum155pl
520
the 509
Mar 9, 2007
  • Mar 9, 2007
there is a little float sensor in the coolant tank .. sometimes it will sink and stick .. mine does it from time to time.. pulling it apart and cleaning it would prolly do the trick..
9
'99 T/A
357
Houston, Texas
Mar 9, 2007
  • Mar 9, 2007
LOL ! At least you guys get a float !
On mine ( F ) the little sensor just screws into the radiator, and over time gets gooped up.
The result ? Low coolant light, even when the coolant is a OK.
So,after going through 2 under warranty the sensor got disconnected.
VOILA ! No more light.
I check my underhood often enough to not need it anyways.
Britt
kingc
85
Spring/Houston, TX
Mar 10, 2007
  • Mar 10, 2007
I have that problem too with the sensor like someone said its a pos. I think to replace the sensor/floaty thing you have to replace the overflow tank/res.
D
Dragstr05
643
Stafford VA
Mar 10, 2007
  • Mar 10, 2007
Same problem here. Been getting quite annoyed with it.
the98stang
2,408
Clovis, CA
Mar 12, 2007
  • Mar 12, 2007
The sensor will go off if you don't have a perfect 50/50 mix of coolant and water. Too much water or coolant will cause it to sink to the bottom of the resevoir and set off the light. If you don't want a 50/50 mix, you can unplug the connector for it, which is located outside of the tank (driver's side) attached to the bottom.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
