  • 1994 - 1995 Specific Tech
Coolant or Water Vapor?
  • Thread starter Thread starter earleys94gt
  • Start date Start date Sep 26, 2007
earleys94gt
1,223
Ashley, Ohio
Sep 26, 2007
  • Sep 26, 2007
I have already done a search, and haven't found anything 'conclusive.' I am having an issue with white smoke coming out of my exhaust; with small amounts of condensation. The exhaust does NOT smell like coolant, and the cooling system doesn't look low. From what I understand white smoke, like a cloud of it, means coolant. White smoke, in puffs, means water vapor. Mine seems like water vapor, because the smoke 'pulses' out with the exhaust.
I am going to check my spark plugs to see if they show signs of coolant. I have checked both #1 and #8 already to see if the engine was running lean, and both had a brownish tint to them.
The only things I can think of are 1.) bad gas with too much 'water' content. 2.) I have a Mr. Gasket 180* and for some reason it didn't fit as well as the stock one. Maybe it is letting coolant by???
Thanks.
94-302-vert
1,947
NE CT
Sep 27, 2007
  • Sep 27, 2007
Run the car up to temperature... if it is running for a while and it is warm out then it is not doing it... water vapor... if it is still doing it after 10-20 minutes... coolant...
cjones
1,561
Avondale, AZ
Sep 27, 2007
  • Sep 27, 2007
white smoke could also mean oil.
does the smoke dissipate quickly or linger??
5.0 from 95
738
Emory, TX
Sep 27, 2007
  • Sep 27, 2007
The ones I have seen that pulse out of the exhaust, is that not a blown head gasket? I also remember reading just a few days ago about somebody giving some information on the brown spark plugs. You might do a search for that if they don't chime in here.
Paul
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 27, 2007
  • Sep 27, 2007
On a cold, damp day, it's normal to see puffs of steam coming out of the tailpipes for a few minutes until the engine warms up but thereafter, there shouldn't be any white smoke at all.
If the white smoke's continuous, the cause is more likely to be a blown head gasket between the water jacket and a combustion chamber and you might not see any contamination of the oil. To find out, you need to pull out all the plugs and see if any one or two are either wet or just look different from the others (light brown coolant stains).
Oil smoke is usually gray with a blueish tinge and has an unmistakeable smell.
cjones
1,561
Avondale, AZ
Sep 27, 2007
  • Sep 27, 2007
you're right about the smell but the blueish gray is when the rings go bad, the smoke is white if the valve seals go bad.
go-stang5.0
2,244
Glenview,Il
Sep 27, 2007
  • Sep 27, 2007
The exhaust will smell sweet if its coolant. Its unmistakable. If it doesnt smell sweet (just burns your nostrils ) then i wouldent worry about it.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 29, 2007
  • Sep 29, 2007
Oil smoke will still be blueish gray regardless of whether the oil's getting past worn rings or worn valve guides/stem seals. The difference is that the condition is worse at idle and under deceleration when it's seals (high vacuum), whereas it's worse under load when it's rings.
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
