coolant problems bypassing cap HELP
  • Thread starter Thread starter stangaddict2007
  • Start date Start date Nov 13, 2007
stangaddict2007
  • Nov 13, 2007
Ive got a 90 mustang gt I just put a new 306 and t5 swap , The problem is the car is spewing coolant past the radiator cap and filling the resevoir and overflowing, This is my 11th mustang and Ive never come across this before, Heres what the car has done 4 core jegs rad., two electric fans, new water pump, new 16lb cap, new 160 thermostat, new water pump hoses , old radiator hoses swelling under pressure,Under drve pulleys, short belt bypassing smog pump, Car reads 150 - 170 degrees on autometer gauge The car had this problem before swap but not as noticeable, In my opinion the fans are 2 small, the radiator could use flushed, the cap may be 2 short or not strong enough , any help greatly appreciated, THANKS
F
Fox8950
247
Nov 13, 2007
  • Nov 13, 2007
Mine puked coolant all over as it was burpin out air bubbles when I was filling the system. Have you run it for a while and it just started doing this or just put it together?
tbovee
129
Fredericksburg Va
Nov 13, 2007
  • Nov 13, 2007
I'd try "burping" again. It sometimes helps to jack up the driver side front to get the radiator filler higher than the rest of the cooling system.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Nov 13, 2007
  • Nov 13, 2007
I'd suspect the cap of being faulty.
The coolant is overheating and expanding and passing by the cap which is supposed to pressurize the system. Some coolant should fill the overflow, but not enough tocome out. Usually just enough to raise the level 4-5 inches in the bottle
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
