I tried to get the Cobra clone smogged today, and the bugger overheated before the test finished.
The fan never turned on at all. I'm replacing the radiator cap as well, it leaked out the side of the cap long before it over heated. I found the 60A fuse for the cooling fan in the fuse box, and it was popped. Explains why the fan didn't turn on. But when I replaced the fuse and hooked the battery up, the new fuse immediately popped. Not so good.
I have a decent voltmeter (tests amps and ground as well), but I'm not sure how to diagnose this. I did hide the wires in the fenders, so it's entirely possible something is shorted or kinked up. I re-used the CCRM from the wrecked Cobra, so it's also possible it's damaged. Can anyone give any advice how to test my wiring? Randomly guessing would take forever. Do I test resistance along the wires, amps, what?
The fan never turned on at all. I'm replacing the radiator cap as well, it leaked out the side of the cap long before it over heated. I found the 60A fuse for the cooling fan in the fuse box, and it was popped. Explains why the fan didn't turn on. But when I replaced the fuse and hooked the battery up, the new fuse immediately popped. Not so good.I have a decent voltmeter (tests amps and ground as well), but I'm not sure how to diagnose this. I did hide the wires in the fenders, so it's entirely possible something is shorted or kinked up. I re-used the CCRM from the wrecked Cobra, so it's also possible it's damaged. Can anyone give any advice how to test my wiring? Randomly guessing would take forever. Do I test resistance along the wires, amps, what?
