cooling issue, and "do i have that part"
LRS has them, but if your car is overheating, that ain't the problem. I've run my LX without it for almost 10 years and never had a problem. My wife's car was running a little warm on the highway last year, I reinstalled it on her car and it made no difference at all. Have your radiator checked out. If it is starting to get plugged up, it can cause the kind of issue. That was the problem with my Saleen when I first got it and ended up being the problem on her Cobra as well.
This thing:
Late Model Restoration part #LRS-8349A, your Price: $34.99
Lems
its not overheating, just getting very warm. much warmer than I have seen in the past.
That piece not only helps direct air in front of the coil but also creates a low pressure area behind the coil to help pull air through it. If it was unnecessary, imagine all the money Ford could have saved by not installing them. ;)
Anecdotal experience varies, as does it matter what model the car is, and if it has a opening in the nose.
Try to ensure the radiator is sealed on the sides and around the fan. With cooling systems, lots of little things add up to help quite a bit.
Good luck.
I say again, spend the $35 to get your radiator flow checked. That piece of plastic didn't lower the temp on my wife's car even one degree, as read on the Auto Meter temperature gauge. Further, if it is a problem that recently manifested itself, it didn't come from the lack of having it on there. There's another problem.
I'd stick it on and see if that helps. It's supposed to be there for a reason. If the rad has issues then it will show with or without that part, but try the simple stuff first
I agree.
Mines been missing for quite some time.
I also get to see under a lot of cars at my buddies shop and i'd say the majority of cars are missing them.
Besides, your car looks to be an lx, which means there is plenty of air going through the grill.
My vote is for a plugged up radiator.
