Cooling Problem!!!
Notch Man
31
MD
I have a 90 lx 5.0. Its has some mild bolt ons. I used an timing chain cover off a lincoln town car, which has a standard rotation water pump (I believe),I have the reverse rotation water pump on my car. Any way my problem, is water keeps pissing out of my over flow tank even when the car is first started. All the gaskets are new on the motor, and there is no water in the oil. The overflow tank is after market. Any suggestions, or need any more info? Please Help!!!-before I yank the motor again!
chec
id check the radiator cap like the guy above said ,than check your weep hole in your water pump to make sure its not leaking, which could mean its not keep ur motor cold, which would make the little coolant yuou have flowing get hot, boil, and overflow
so when you first start the car, the radiator is already full (had not receded from when it cooled off the night before)?
