cooling probs
firetender
Hi everyone... I have a 94 3.8 stock pony with a/c. I recently changed the cracked radiator with an oem replacement one. I filled with coolant and started engine, no circulation. I removed thermostat to see if sticking, still no circulation. I removed lower hose thinking might be obstructed or collapsed and ran water through radiator, water comes out of lower hose. I removed upper hose with engine running, nothing coming out. I added water through upper hose thinking maybe engine block might be low on water, still no circulation. I reinstalled old radiator to see if new one might be blocked, no circulation. I removed water pump and replaced with new oem replacement, no circulation. I was very careful in reinstalling serp belt as I know that if not correctly reinstalled could cause pump to run backwards. Any help would be greatly appreciated. Engine has NOT been rebuilt, original radiator was replaced as it had a crack at the upper hose mounting location.
Thanks
