cooling question
  • Thread starter Thread starter 66coupe306
  • Start date Start date Feb 1, 2004
66coupe306
32
  • Feb 1, 2004
Anyone having cooling problems? I have clearance problems with most electric fans or at least any that put out enough cfm to cool properly. What are you guys using?
crushnut
870
Oregon
Feb 1, 2004
  • Feb 1, 2004
Stock fan, stock radiator and 180 degree thermostat, no cooling problems here.
66coupe306
32
  • Feb 1, 2004
I am using a flex fan W/ shroud and have a griffin. I don't have any prolems now, its cool as a cucumber, but I will propably need an electric once I install the blower because of clearance. Last electric fan installed did not work well.
crushnut
870
Oregon
Feb 1, 2004
  • Feb 1, 2004
Ah i see
1969mach1351
285
Sacramento, CA
Feb 1, 2004
  • Feb 1, 2004
I have a Spal fan; I think it’s a 16 inch puller with about 2300 cfm. I had a pusher but that didn’t work for me. When I bought it I assumed the center of the fan would be centered on the water pump, but there is more room if you don’t do that. I ended up offsetting the fan about half an inch to one side witch gave me enough room. The only thing that you might not like is that it pulls 22 amps but my stock alternator has been fine for a year. The fan only comes on when it is above 60 degrees out or when I’m in lots of traffic.
I have a 4 row radiator with an aftermarket water pump. I'm sure you have less room in your 66, good luck.
G
gp001
4,401
So. Cal.
Feb 1, 2004
  • Feb 1, 2004
I run a Flex-a-lite #475 fan/shroud combo. It is similar to their Black Magic fan just thinner.
G
GaPonyFarm
663
Columbus, GA
Feb 1, 2004
  • Feb 1, 2004
Modine 4 row radiator, Hot Road Air electric fan with adjustable thermostat, March pulleys...clearance? about 1/2"...
Skip the 4 row radiator and use a 3 row...saves money and space. The 4 row is overkill. The electric fan helped immensely.
calpolymustang
217
Santa Rosa, CA
Feb 1, 2004
  • Feb 1, 2004
cooling
go with the $200 one in summit by flexalite (400-150). its loud and big, but i know a few guys with one. i still have a pumpdriven fan, but will eventually go with a powerful one. buy a good one the first time
as far as radiators are concerned, a three row should work with a street car. what i found was that my radiator kept plugging up with chunks of my engine block. i put a Gano filter in and it hasnt overheated since
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Feb 2, 2004
  • Feb 2, 2004
This was a fairly recent thread on this subject.
http://forums.stangnet.com/showthread.php?t=407964
This should be listed as a FAQ since it is such a common problem!
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
Z
Cool fan issues
  • Zipcity
  • Dec 23, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 27, 2025
manicmechanic007
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
