Cooling system problem?
  • Thread starter Thread starter jabGT
  • Start date Start date May 18, 2005
J
jabGT
59
Michigan
May 18, 2005
  • May 18, 2005
I am looking for some advice before I pull the heads to change head gaskets?
I am getting bubbles in overflow, but it won't happen when car sits and idles from a "cold" start until 15-20min, just after driving it a short distance, taking it easy or driving hard doesn't make a difference(supercharger off car). I have tried burping the system multiple times, but when I open the cap when idling (engine not hot yet) the coolant will just overflow the radiator neck. After a drive, radiator cap(new cap) is hissing and if I crack it slightly the overflow will bubble like crazy, big bubbles and small bubbles but no "foam". Pulled all plugs no sign of coolant nor can I smell or see burning coolant in exhaust and no coolant/oil mixture. Coolant does have alot small gray specs in it, but I assume thats from the last time a had the heads off. There is a slight iridescent film on top of coolant. Car does run slightly hot when idling 210 -autometer gauge, M on NORMAL on stock gauge, but while driving temps go down to 190-195. Upper radiator hose rock hard after shutdown, squeezing it while thermostat is open I can feel bubbles cavitating through it.
Is it possible that from opening and closing rad. cap so much that I am getting to much air into the system and not allowing it to burp itself?
I did have cooling leaking out the timing cover gasket when I pressure tested the cooling system(lost 1-2 psi over 15 mins) could this have anything to do with it?
Could a have a clogged radiator?
When I open the cap would it cause the coolant to boil (if coolant was in bad shape) because of reduced pressure?
Any other ideas or opinions would be appreciated, I would hate to swap out head gasket just to have the same problem.
Sorry about the long post?
Thanks
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
