There are two "temp" sensors...the one that matters the most is the coolant temp sensor. This sensor is located in the crossover tube that goes to the heater core. It is basicly right next to the alt. it should be sticking straight out of the hard line that is bolted to the lower intake. This sensor is the one the EEC uses and one function is for sending the temp to turn on the fans.
The next is the temp sendor that sends the voltage to the cluster gauge in the dash. This only effects the guage nothing else. It is located on the lower intake as well on the drivers side accross from the temp sensor.
The level sensor is on the overflow. The plug in on the overflow is the low sensor as far as I have noticed.
