  • SN95 4.6L Mustang Tech
Copper plugs?
  • Thread starter Thread starter turboscrew
  • Start date Start date Jul 30, 2004
T
turboscrew
131
  • Jul 30, 2004
Is there any benefit or any gains if you switch to copper plugs in 99+ GTs with just basic boltons?
ADRENLN
2,342
NJ
Jul 30, 2004
  • Jul 30, 2004
what brand copper plugs are you going to get?
T
turboscrew
131
  • Jul 30, 2004
Motorcraft or NGK
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 30, 2004
  • Jul 30, 2004
get the Autolite 764's. they are the motorcraft plugs, but only cost $1.50 a piece. autolite=motorcraft.
T
turboscrew
131
  • Jul 30, 2004
But is there any sense in changing them from platinums? Will the coppers run better or help performance any?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jul 30, 2004
  • Jul 30, 2004
I have Motorcraft awsf-c12's in my car gapped at .054 and they work great. They are two steps colder than stock and copper. Copper is better in terms of performance since it is less resistant to electrical charge than platinum. However, you have to change coppers more often. I'de say just use coppers and change them out every year. As for which brand, I don't know if Autolite and Motorcraft are the same but I do know Fords come equipped with Motorcrafts and I know many guys using Autolites without problems. It should be noted the Autolite 764's are stock heat range. For better performance, might want to try 1 or 2 heat ranges colder than stock. Gap them at .054 for a n/a application.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 30, 2004
  • Jul 30, 2004
yes the coppers are better. platnium plugs are only in there because they last 100k miles and ford doesnt have to deal with changing them under warrenty. on a car that is easy to do plugs on like a mustang (do a toyota camry v6 and u know what i mean by hard) just use coppers.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 30, 2004
  • Jul 30, 2004
o btw autolite makes the motorcraft plugs. ford and autolite have a long history together. a lot of the carbs used on fords were autolite carbs. people think that the motorcraft oil filters are fram because autolite/prestone/fram are teh same company. motorcraft oil filters are wix/purolator depending on who they use that week.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Jul 30, 2004
  • Jul 30, 2004
Thanks for the clarification Bdcardinal.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
  • Mindseye007
  • Aug 16, 2026
Mindseye007
