Correct Cam Position
  • Thread starter Thread starter abnovak
  • Start date Start date May 13, 2006
A
abnovak
28
  • May 13, 2006
Still trying to diagnose problems with a poorly running engine. I did find that I had 2 bent push rods, but I think it happened when I was swaped heads, rather than the cause of the original problem.
When I found out I had bent the rods, I pulled the tappets to check them and the cam. As I explain in my originial posting below, I don't really know much about the long block I purchased.
http://forums.stangnet.com/showthread.php?t=635110
When I pulled the tappets and lobes, everything was fine. But, when I checked the cam lobes, they are visually not centered in the tappet holes. They appear to be off center to the back. I not sure sure the original builder used the right cam.
Is this normal? yes, I am a newbie but trying hard to learn. thx
D
D.Hearne
11,730
south louisiana
May 13, 2006
  • May 13, 2006
Yea, that's normal. The lifter rides one side of the cam lobe and thus the lobe spins the lifter in it's bore. This evens the wear on the lifter and reduces friction. On the 2 bent pushrods, did you check those two lifter bottoms ? If the lobes are wiped they'll wear the lobes abnormally. Usually happens when the lifter fails to spin at initial startup. Bent pushrods are also a result of wiped cam lobes. The lobe and lifter wears far enough to where the rocker and pushrod get loose and the pushrod gets ****-eyed and then bent when it gets into a bind.
A
abnovak
28
  • May 13, 2006
Thanks - The rods and lifters were new and not worn at all. I have checked them and they appear to be ok. I am sure it was my own sloppiness when I tightened the rocker arm assembly. I probably didnt have them positioned correctly.
Oh - and sorry for the double post. Not quite sure how that happened.
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
