correct me if im wrong but.....
96 GT JOE
56
i am doing a pi intake swap on my npi 96 gt here is all the parts i have in my garage. is there anything i am missing!!!???
- pi intake w/ aluminum crossover
- tap for second temp sensor
- pi intake manifold gaskets
-water pump o-ring
-water pump gasket
-upper plenum gasket
-rtv
is there anything else i need b4 i take it apart!? please let me know. thanks
PI coolant hose and nipple
PI Alternator bracket.
thats all i can think of
Here are the parts and numbers...
*Thermostat housing o-ring: F1VY-8507-A
*Heater/coolant tube: XR3Z-18B402-AA
*Water pump nipple: F75Z-8555-AA
*Water pump o-ring: F1VY-8255-A
*Alternator bracket: 1R3Z-10153-AA
The alternator bracket you have now can be modified to work...just have to drill a new hole.
which tools do you have?
We started my non pi to non pi repair swap lastnight.
We needed
fuel line disconnects
stocket wrench to take apart everything (mostly 10mm sockets)
torque wrench to put everything back together correctly.
abunch of sandwich bag for screws
maskin tap to make sh !t
and abunch of time if this is your 1st.
anyways we went from 2pm to about 5pm =( and didnt get much done b/c where noobs @ this stuff..
good luck man and enjoy your new powa!
Disturbed One said:
What about the heater hoses? Don't those get routed a different way? Also I believe the coolant/oil plugs from your heads need to go on the new heads so don't forget to do that.
That's the coolent tube listed in the above parts list that droptop put up...and you can't do without the water pump nipple.
You can use the old alt bracket but the holes don't match. Just drill new one.:nice:
The only tip I can remember is when removing the old water pump nipple use a socket that just fits over the tube then hammer it out. This keeps it from flaring and making it impossible to slide through the hole with out borrowing a neighbors Sawsall.
