Correct Tb For Explorer Intake?
fiveoho
1,958
TN
little confusion here... considering buying a cheap explorer upper and lower for my 90 GT. i want a TB to install with it. will a 87-93 mustang 5.0 specific 65mm tb bolt right up to the explorer intake with no modification? or do i have to use a explorer tb? i was thinking one of these requires a little custom work.
thanks
The explorer is a 65mm as stated you have to mod the cable lever. Its easy to do. If you compare it to a stock mustang one you can see the difference.
i appreciate the responses. will a stock gen 1 lightning TB work for what i am doing? should bolt right up to a explorer intake and still keep my linkage in factory location correct?
i believe the gen 1's are 65mm.
