could it be timing or fuel??
  • Thread starter Thread starter llvllanifest_23
  • Start date Start date Mar 3, 2007
L
llvllanifest_23
  • Mar 3, 2007
i just purchased an 87 lx 5.0 .the problem im having is that i cant seem to get past 3500.rpms .it seems to not gain after i reach that point. i had thought i was a bas eec processor so i got another one and it didnt make a diference.i havent got as far as getting a new pump because it seems to be working fine but i did mess with with the timning quite a bit.it helped a little but its not what a 5.0 litre should be at..i cant figure it out and i dont want to spend too much money..i mean i will knowing what the isssue is but i wont spend money trying to guess .any help would be appreciated
HISSIN50
34
129
Mar 3, 2007
  • Mar 3, 2007
I'd pull codes first.
I'd want to examine the plugs. Plats can cause issues at higher RPM's.
I'd also consider the ignition coil - around 3-4K is when they often start to cut-out if the coil is on the outs.
There are other items but generally they are temperature dependant and degrade the hotter they get.
Good luck.
L
llvllanifest_23
  • Mar 3, 2007
thank you..i will try that..i have checked for codes but it wouldnt pull anything..but i will check the coil..it makes perfect sense.ty
Fett
766
  • Mar 3, 2007
Also don't forget the easy things. Make sure your air filter isn't clogged, or there isn't any restrictions in your air inlet. Also, check your exhaust, make sure you are not having any clogging issues there.
myslo50
247
ohio
Mar 3, 2007
  • Mar 3, 2007
if it sputters, prolly lack of fuel or spark. you didnt specify?
if it has orig cats on, pos it could have clogged cats?
L
llvllanifest_23
  • Mar 3, 2007
true..but i have no cats. and i have checked the air filter and it looks good to me..i do appreciate your input..your right though it feels like some sort of restriction
L
llvllanifest_23
  • Mar 3, 2007
no sputter .just a slight hesitation..like a a timing issue or worn timing belt.could a fuel pump be weak yet stll work??
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
J
68 Mustang with Foxbody Engine Stalling Issues - MSPNP2
  • JayV68Stang
  • Mar 13, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Mar 13, 2025
JayV68Stang
J
N
50 miles on 1/2 tank of gas
  • NooStang
  • May 13, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2025
NooStang
N
