Greetings,
Long story short, dropped small metal object down intake runner #1. Turned engine to TDC #1, and then a full rotation to get to TDC w/ valves closed. Had to take the head off to get the part out.
After reassembled, did compression and then leak down and found that while compression on #1 is in the ballpark (down 10-15%), LEAK DOWN is 60% - only 40% of the pressure I'm putting in is staying in the cylinder - and most of the air is coming out the intake runner....
I took the rocker arms off just incase I had a geometry problem that was keeping the valve open and the results were the same.
Could closing the valve while a small object was in the way cause the valve to bend such that it won't seal?
If so, what are my options - new valve - any others?
THANKS!
THANKS!
