Cracked Block?
Maybe I should explain a little more. I went to look at this mustang in the local paper. The car has been sitting for a year or so. We jumped it and got it running. It ran good. It was leaking coolant as fast as you could put it in so we didn't run it long. I haven't had the chance to crawl underneath it yet. He said it was a freeze plug that popped out.
sbftech said:
ya they dont just pop out, the block twists, flexes and then they pop out.
I've read many posts where the owner replaces the freeze plugs and everything is fine and dandy. How would the car run with a cracked block? I mean, would it run at all? Worst case, I can part the car out and get my money back but I think it's fixable. Am I missing something here? I can fix little things but I want to make sure I'm not getting in over my head with a busted block or something.
ya owners replace expansion plugs when rebuilding, NOONE just replaces them with the engine in the car for no reason. Its not a wear item. Hey what do I know
You misunderstood me. I'm not saying people change their feeze plugs when they change their oil, like it's a routine maintenance item. What I am saying is that sometimes the freeze plugs have popped out and the owners replaced them (installed new ones) without having any damage to the motor.
in the last 20 years and dozens and dozens of my own personal engines it has never happened to me. Furthermore in my 9 years working at Ford I never saw it once. The one time I did experience it was when a friend I built a motor for (351w) was at the track, popped a plug and ran over his own antifreeze and clipped the wall. This was a serious HP application and the block twisted and flexed resulting in the plug popping. In my experiences it has never happened. Something has to happen to make this possible. The only way to make sure everything is fine is mag the block.
Fair enough. I'm thinking they didn't have the proper mixture of coolant/water over the winter and the plug (s) popped out. I was mainly curious if the car would run at all if the block was cracked. The car seems to run fine for what little time we had it running.
Ya it will run, for how long? Who knows. The worst case scenario is you pop another one back in, it pops out later, you run over your own coolant and hang on. :D Most likely what you suspect is what happened. That water has a long way to expand and must exert a fair amount of pressure to pop the plug out on it's own. I would err on the side of caution and use it as a bargaining tool to get the car for next to nothing.
The body is a 3/4 out out of 10. Rust on the passenger side. I have wanted to find a car to take to the dragstrip. If I can buy this for $500 and fix it for cheap, I thought I would give it a shot. I don't think it's worth putting a junk yard motor in it.
I, also, have been a tech for years and I have NEVER seen a freeze plug just "pop out" That's rediculous. They usually will rust from the inside out and create a small pin hole that gets larger and larger with time.
I've seen blocks that are split right down the middle and make it home from teh track. Usually the block will only crack under extreme hp, not from just beating the crap out of a stock motor.
Nick
well i had baught a 91 gt and told it ran fine but blew a head gasket b/c some retard only tighten the heads to 60ftpounds lol. well he drove the car for about 60 miles while hot surpiseingly it didnt granade itself well it wound up being cracked between num 6-7 the car ran hot but was still drivable as long as it didnt have a rad cap on lol i wouldnt recomend this though. lol
