Cracked cast iron manifold
crushnut
870
Oregon
67coupe351w said:
How possible is it to weld shut a crack on a cast iron exhuast manifold?
I have heard that the whole peice would need to be pre-heated and stick welded. Anyone know anything about this? Can I use my wirefeed on it?
I know normally you dont want to weld on cast iron becasue it weakens it but im just looking to seal the crack and illiminate the noise.
If you TIG weld it then it doesnt need to be pre-heated.
Yeah headers would be cool if I felt like wasting money on a vehicle other than my mustang :D
What im wondering though, is will my wire feeder actually work. I was told the bead would just roll off the cast iron as I tried to weld unless it was preheated and stick welded.
hit it with a bead and see what happens, I'm pretty sure you can buy cast wire for the mig.
I have fixed exhaust manifolds and heads using a nickel based welding rod for my AC arc welder.I didn't preheat but I made small beads about an inch long and waited a minute or so to let it cool before I put the next one down.If cast iron gets too hot in one spot it will crack as it tries to expand so if you don't preheat you have to go slow.
I took a cast manifold to a boat shop where they repaired it. It was cracked 3/4 the way around. It was done by pre-heating with a torch to a cherry red, then hit with the nickel based rod with an arc welder. Aparently boats need a lot of welding done on cast iron.
Unless you have the equipment and the technique down, I'd call around for a welding shop to do it. The problem that I've had in the past welding cast is controlling the cooling. If it cools too fast, it's gonna crack and you'll be right back where you started from.
