well, noticed today one of my 7000K Krypton gas fog lights was burned out...
so, I took off the casing and noticed it was cracked... I assume from the heat. So, I can't eppoxy the case because the crack is under the mounting bracket, so I need new a new light housing.
http://www.mustangsunlimited.com/aspfiles/itemdy00.asp?UID=2004021113433211&T1=945203L+01
These look good, anyone bought these before? do I need to transfer anything to them to make them fit right?
so, I took off the casing and noticed it was cracked... I assume from the heat. So, I can't eppoxy the case because the crack is under the mounting bracket, so I need new a new light housing. http://www.mustangsunlimited.com/aspfiles/itemdy00.asp?UID=2004021113433211&T1=945203L+01
