Crane 1.7's - Do I need new pushrods?
New pushrods
Your stockers should work just fine, I would buy the shim kit for pedestal rockers however, so you can set proper "clearance". Unless your heads were shaved excessively, you should have no problems at all. Also, you have to remove the baffle under the oil filler on the right side for clearance.
Wow I guess I was lucky....I used FMS 1.72's with stock heads shaved .020" and used the shim kit. I drove the car from Fl to NJ round trip and put a whole season of autocrossing and another 25K miles on it until I did the E-cam/FMS1.6 RR's and noticed a perfect wear pattern across the tops of my valve stems. Maybe the Crane Cobra style RR's need a longer pushrod...I stand corrected. :shrug:
I just put a set of thumper heads on my car they were shaved .40 and had the same question e mailed mike at thumper and he said push rod lenth would be fine just had to shim rocker arms I am running ford 1.7
