Crane Hi-6S Ignition Kit
krahkin
183
Acworth GA
Anyone running this? I have a question or two, and need to talk to someone who has installed one of these on an SN 5.0.
I bought the adapter kit to go along with the ignition box/coil. Did you have to extend any included wires to reach both OE connectors? I dont see how I can place everything and have enough to reach with the supplied connectors.
Also, where are some good mounting places?
i mounted mine on top of the fuse box.just marked and drilled 4 holes,bolted it on and ran the wires under the box and ran the wires along the alt wires already there and zip tied them to those.no problems with the hood clearing and i can still run my brace.and you dont have to extend any wires.hope this helps.
Well, maybe Im just confused as to where I am to connect the 2 plugs coming out of the box. I thought the coil and the box under the MAS. Is this correct? If so, how did you reach them both? If not, where do I connect the darn things?
both plugs require adapters that you should have gotten with the kit,you plug the adapters into the only 2 wires,besides the ground,that you need to use.then one plugs into the wire going to the coil now,then the other plugs into the coil.you have more than enough wire to reach if you mount it where i did.if you're still confused,i'll try to help more.all youre really doing is connecting the coil to the box and then box to the coil.but nothing goes by the mas.
