cranking problems.
  • Thread starter Thread starter hottrodd84
  • Start date Start date Mar 11, 2004
H
hottrodd84
Monroe, La.
Mar 11, 2004
  • Mar 11, 2004
Help, here is my problem, I have a 84 5.0 with 4 barrell carb, anytime i try to creank and the tach does not move car will not crank, If it does Move car cranks right off runs like a charm, i can go a million miles if i want to, the only thing is, when i cut off and wait about a minute to crank tach won't move and car will just turn over, but if i crank again immediately after cutting off car cranks fine. I have already changed coils, modules, and the plug wires several times, nothing seems to help. Any Suggestions?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 11, 2004
  • Mar 11, 2004
Here's a checklist:
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Check the cables for cracks in the insulation, and corrosion around the wire where it joins the connector. Look for swelling of the cable’s diameter which would indicate corrosion inside the cable. Bending the cable can often reveal corrosive damage inside the cable when the outside looks OK.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw) and jump it to the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then the relay is bad.
6.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
7.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
8.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
9.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 11, 2004
  • Mar 11, 2004
You mean that the starter does not turn the engine ? OR does the starter turns the engine, but it doen't fire up and run?
H
hottrodd84
Monroe, La.
Mar 11, 2004
  • Mar 11, 2004
jrichker said:
Here's a checklist:
H
hottrodd84
Monroe, La.
Mar 11, 2004
  • Mar 11, 2004
ok, let me clarify, the car will turnover fine, there is no need to jump, becase the engine is turning, it's just not firing, when the tach guage is moving that't the only time it is firing. When the tach is still no matter how long you crank on it or pat the accelerator all you will do is flood, you can also tell that it is getting gas. When it is firing it will crank on the first turn and run like a sewing machine, turn it off immediately crank it again same thing, turn it off and wait about a minute and it will not fire, tach will not move, and the car will not crank, it will however turnover so neo need to jump.
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
  • dan50
  • Jul 18, 2026
dan50
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
P
Crank but no start BUT no power to gauges
  • project_88LX
  • Jan 13, 2025
Fox 5.0 Mustang Tech Jan 14, 2025
Mcmahst
