alright, just yesterday i replaced the radiator that cracked on wednesday night and all was fine and dandy. i go to my bro-in-law's house to help him do yet another engine swap and cruise home fine afterwards. i'm going out w/ my gf that night, and on the way to her house my car starts to overheat (got to the L on the temp guage). i immediately pull over and let it cool off. once it does, i start it back up and noticed the fan wasn't turning on. i pop the hood and smack the ccrm a few times until it does (and also turned the a/c on high/max) and it begins to cool, finally.
i go home to get the Jeep, not wanting to risk anything with the car, and as i'm about to pull up to the driveway, there's a loud backfire (that sounded like an exhaust backfire) and the engine shuts off. i try and start it, but all it does is crank and crank and crank. we pushed it up to the driveway.
i go outside today and check the following:
-fuel pump safety switch--on
-verify that maf, tps, iac are connected
-check to make sure the dizzy isnt' loose
-checked 5 of 8 plugs that all look ok
-checked the connections at the dizzy, coil, and wires (including the wiring harnesses that connects to the dizzy and coil)
-check to make sure the 2 harness i disconnected while swapping radiators were well-connected
when i turn the key, i can hear the fuel pump prime. i tried priming it thrice before starting and no change--it just cranks and doesn't fire.
i'm thinking i should check the fuel pressure, but i don't have a guage to connect to the rail.
how can i check for spark?
think the ccrm could affect this? i know there's a relay for the fuel pump, but i do hear the pump prime...?
