- Aug 13, 2006
- 185
- 0
- 0
I've got a problem that got me stumped. When I start the car up in the morning in cranks for about 2 seconds and starts right up. When I drive it around and it gets up to temperature 180*, and I come to a stop, turn it off, let it sit for a few minutes. Then try to start it again most of the time it can crank for about 10 seconds before it starts. When it does start it tends to stumble slightly until I hit the gas. I just replaced the distributor and TFI module with no luck at all. I'm starting to think it is a fuel problem, because it cranks strong, but stumbles until the gas is pressed.
Question: When you turn the key to on. Should I have fuel pressure on my guage at the schrader valve? Mine reads zero until I start cranking it. Then it bounces around until the car starts then it goes pretty steady to the setting that I set it to.
Any help you can provide would be greatly appreciated.
Joe
Joe
