Crankshaft Damper
  • Thread starter Thread starter Stang&wake
  • Start date Start date Aug 16, 2005
Stang&wake
12
Nor Cal
Aug 16, 2005
  • Aug 16, 2005
I am trying to get to my timing chain to replace it with a new one but i can't seem to get the crankshaft damper to come off. Whenever i try to break it loose the pully and damper just spin. How do I get it off. Please help.
Eric
G
grego37
576
Fresno CA
Aug 16, 2005
  • Aug 16, 2005
you need to go to your local parts store
autozone/kragen
and rent / borrow a damper puller
Max Power
1,774
St Paul
Aug 16, 2005
  • Aug 16, 2005
To get the bolt loose, which sounds like the problem you are having, you need to stop the engine from turning while cranking on it. With an engine in the car, I do this by pulling a spark plug and sticking the end of a rope or cut fan belt in there. When the piston comes up against the rope, the engine will stop turning.
D
D.Hearne
11,730
south louisiana
Aug 17, 2005
  • Aug 17, 2005
Even easier is to remove the flywheel/flexplate inspection cover from the bellhousing and jam a screw driver into one of the holes in the flywheel/flexplate, then turn the crank till it's jambed against the bellhousing.
65up2d8
281
Memphis, TN
Aug 17, 2005
  • Aug 17, 2005
That also sounds better from the standpoint of introducing dirt, rope, and/or fan belt particles into the cylinder. I know it would be above the rings, but it still sounds like the better of the two options.
Edbert
3,548
32
109
Austin TX
Aug 17, 2005
  • Aug 17, 2005
Agreed!
You should try to keep even dust out of the inside of your motor if possible.
66P51GT
721
Cerritos, CA
Aug 17, 2005
  • Aug 17, 2005
That's a new one... please use the alternative method of removing the bell cover and lock the flexplate. With this method, you will probably f**k up your valvetrain since the rope/fan-belt is getting pinched between the valve and the piston!
M
mustangman70
1,235
St pete, Florida
Aug 18, 2005
  • Aug 18, 2005
#2 for the puller, they are cheap man like 10 bucks, just go buy one
SoCalCruising
2,437
SoCal
Aug 18, 2005
  • Aug 18, 2005
Then there's the one where you put a socket and breaker bar on the bolt and jam the bar onto to something in the engine compartment and then turn the engine over with the ignition switch (coil wire is off the distributor, of course). I read that on this board onnce - never tried it.
iskwezm
4,159
20
79
Rowland Heights,California
Aug 18, 2005
#10
  • Aug 18, 2005
  • #10
use a impact,electric or air
RFMustangGT
294
Knoxville,TN
Aug 18, 2005
#11
  • Aug 18, 2005
  • #11
impact should bust that sucker on out!
M
MitchGT
204
Aug 21, 2005
#12
  • Aug 21, 2005
  • #12
Once I rented an impact gun it came off in about five seconds.In fact, it came off so fast it the impact ran into the radiator as the bolt unscrewed. Luckily there was no major damage. Anyways, while you are renting that, rent a balancer puller too. there is no good way to pull the balancer without it, and it only costs something like ten or fifteen buck. Thirty bucks and ten minutes with both tools rented.
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Axleback installation
  • Bob Foos
  • Jun 13, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
