There were also differences between the engine tune. I forgot the details, but for SAE gross measurements, the engine tune was basically according to the "blueprint", whereas the for SAE net measurements, the borders of the tolerances of the tune were used, like ignition timing at 5% from optimum or something like that. This was used to account for production and installation variations and wear. In other words, SAE gross specs were kinda like "300 hp on a good day", and SAE net are like "200 hp guaranteed, more in most cases".
This also explained that although cars got noticably slower after 1971, the difference was not as dramatic as the HP numbers would suggest. That is, for somewhat comparable engines, like a 351C 4V from say 1971 and 1973.
When it comes to accesories, the alternator is usually brought up, but an alternator doesn't use all that much power. If you take a typical (in those days) 65A alternator which gives 14V, the electrical power is 1,2 hp. Electrical machines typically have 70% efficiency, so including some losses in the belt drive, the loss may be 2-3 hp, MAX. A lot less when it doesn't charge.
Installing a stock exhaust system has of course a significant effect on power, especially those old ones. A mandrel bent 2.5" system on a modern Mustang is a lot more efficient.
Funny that the Ford catalog mentiones the starter. IMO, it just hangs there during a dyno test, doing nothing.
