crate engines
  • Thread starter Thread starter 66'Stanger
  • Start date Start date Apr 25, 2004
1 of 2 Next Last
66'Stanger
87
Tucson, AZ
Apr 25, 2004
  • Apr 25, 2004
My 289 in my 66 is finished and now I'm looking for a crate engine. where is the best places to get one? I'm thinking about getting a 351W
sand1man
299
Charlotte, N C
Apr 25, 2004
  • Apr 25, 2004
http://www.coasthigh.com/
http://www.dssracing.com/
I have heard really good things about both of these
one2gamble
902
Monterey
Apr 25, 2004
  • Apr 25, 2004
order one from ford
F
Fomocohipo
128
  • Apr 25, 2004
Those are really good places.
www.Speedomotive.com has the cheapest i found, but dont know about the quality
Get the coast high 347, it should be a easy fit in the car and good cid too. But make shure to get the one with the shorter rods (3.15"??) and taller pistons. Its a little more money but they dont have as much oil blow by and last longer than other 347's.
RajunCajun
180
  • Apr 25, 2004
www.fordracing.com
havent used these people but heard of them lots
www.dndmotorsports.com
Snail50
787
Miami
Apr 25, 2004
  • Apr 25, 2004
I think one of the members here had a bad experience with Speedomotive, but I can't remember who it was.
'69Mach1Chick
There's no grass left to cut.
Apr 1, 2002
348
North Jersey
Apr 25, 2004
  • Apr 25, 2004
hey can someone please give me all the details about the difference between a clevland and a windsor???? And besides the fact they are named after where they were made
67GTCOUPE
653
Land of Ice and Snow
Apr 25, 2004
  • Apr 25, 2004
Do you have any mechanical skills or have friends who are mechanics?
Personally I suggest building your own motor....that way it is exactly what you want!
You won't go wrong with a Ford Racing Crate motor, if you aren't able to build your own.
F
Farls
11
  • Apr 25, 2004
What about these guys?
http://www.fordcobraengines.com/Power2.htm
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 25, 2004
#10
  • Apr 25, 2004
  • #10
Try a search for crate engines also, we 'bout beat this to death almost a week ago.
http://forums.stangnet.net/showthread.php?t=454038
Cleveland and a Windsor have different blocks, different main journals, different intakes, different heads (and valvecovers) although the bore centerlines between the two (and a 289/302) are the same. That's in a nutshell. A 351C water exits thru the front of the block instead of the face of the head into the intake. A 351C flows no water thru the intake. The main journals are smaller on a 351C than a 351W though bigger than a 289/302. The deck height is taller on a 351W (0.298") and the rods are longer than a 351C (0.176", but the bore and stroke and rod journal size remain the same, the difference is made up by the 351C's shorter piston compression height (0.122" diff).
Edbert
3,548
32
109
Austin TX
Apr 25, 2004
#11
  • Apr 25, 2004
  • #11
Good stuff 1320, you forgot to mention the canted valve setup on the Cleveland heads, they are certainly better for power than inline Windsor types. Of course the aftermarket more than makes up for that difference, and aftermarket parts are more plentiful, meaning you have a better selection.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 26, 2004
#12
  • Apr 26, 2004
  • #12
DOH!!! yeah, you're right, that's a pretty big difference. I also didn't mention that you can put the C heads on the W with a little work to the heads and the Track Boss intake or that the NASCAR Ford Engines use a Cleveland styled head on their Windsor based motors. I also didn't mention the difference in weights in stock based motors, but I don't know what those weights are.
Hack
1,945
Minneapolis
Apr 26, 2004
#13
  • Apr 26, 2004
  • #13
A table I found online said this regarding engine weights. This is supposed to be the total weight with accessories.
289-302 460
351W 525
351C 550
dodgestang
1,360
Cecil County, MD
Apr 26, 2004
#14
  • Apr 26, 2004
  • #14
that would be me...stay away from speedomotive...I dealt with them for a stroker but I would not expect them to treat people any different with one of their crates...VERY long story short, they built me parts, admitted to making those parts to the wrong specs and I still had to eat the cost of the parts.
'69Mach1Chick
Apr 1, 2002
348
North Jersey
Apr 26, 2004
#15
  • Apr 26, 2004
  • #15
Thanks guys, good stuff keep it coming!
66'Stanger
87
Tucson, AZ
Apr 26, 2004
#16
  • Apr 26, 2004
  • #16
So far I'm most interseted in this crate motor.http://www.fordcobraengines.com/351W_400Carb.htm
kslushy
1,125
Apr 26, 2004
#17
  • Apr 26, 2004
  • #17
Both Dss and Coast have good/bad reputations with different people. If you want a well made crate motor, that arguably uses inferior parts (ie rod bolts), get a FRPP one. Its so easy just to change out the rod bolts anyway. The clearances should be uniform across the whole production run, instead of off/on as with a handbuilt one.
Besides, you should always double check anything anyone or even yourself built before putting it in your car anyway.
F
fastcoupe68
368
nj
Apr 26, 2004
#18
  • Apr 26, 2004
  • #18
Kuntz and Co. and also Kieth Kraft Racing, two of the very best out there. There reputations speak for themselves. If your serious about getting the best these guys cant be beat.
R
Ronstang
1,294
Houston Texas
Apr 27, 2004
#19
  • Apr 27, 2004
  • #19
I agree that ARP rod bolts are the best but don't count Ford out as their quality isn' too bad. My budy has a short block from them that is basically the Sportsman 351 block with all truck internals. We have Edelbrock Victor heads and the engne consistantly spins to 7000rpm at the track and runs 11.4s on slicks. The only breakage we have had on this car over the last couple of years was a Crane ignition system and the Tremec he spattered a few months ago. I agree that ARP bolts are the best but for the average engine the Ford stuff is fine.
66'Stanger
87
Tucson, AZ
Apr 27, 2004
#20
  • Apr 27, 2004
  • #20
What do you guys think about the engine that I have posted? Has anyone heard anything about that website? That is pretty much exactly what I'm looking for.
1 of 2 Next Last
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
D
88' Foxbody GT Engine Tips
  • drefrmdasouthbay
  • Mar 19, 2025
  • The Welcome Wagon
The Welcome Wagon Apr 5, 2025
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
N
Trying to locate 1968 Mustang
  • Newton
  • Jul 1, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 1, 2026
Newton
N
