  • 1994 - 1995 Specific Tech
Crazy Vibrations
  • Thread starter Thread starter Guero
  • Start date Start date Jan 15, 2006
1 of 2 Next Last
Guero
2,148
Jan 15, 2006
  • Jan 15, 2006
Everytime i pass 3,000rpms in 5th gear and let of the gas it vibrates like a mofo, and it gets even worst if i put it in neutral. vibrations comes from the shifter handle. what could be wrong? i had mentioned before but i forgot about since i really dont stomp on it very much, or drive it.
HISSIN50
34
129
Jan 15, 2006
  • Jan 15, 2006
Could be as simple as a driveline vibration (as the DS approaches critical speed, esp with your 3.73's, any imbalance starts to show itself) or an absolute speed issue with something like a tire.
Based on the info given (that it is an absolute speed issue, not an issue at a given RPM in every gear, or while stationary, etc), that is my guess.
Good luck.
CManT1914
3,172
Killeen, Texas
Jan 16, 2006
  • Jan 16, 2006
JT is right on. Seems to be a drivetrain issue. My friend's 2000 GT vibrates horribly in 5th after 100mph, his passenger side axle housing is bent.
Guero
2,148
Jan 16, 2006
  • Jan 16, 2006
whats an axle
94-302-vert
1,947
NE CT
Jan 16, 2006
  • Jan 16, 2006
driveshaft.
Had the same prob heere after my 3.73's.
HISSIN50
34
129
Jan 16, 2006
  • Jan 16, 2006
Guero said:
whats an axle
For real?
They are the little sticks that transfer power from the rear gears in the middle of the car, to the wheels.
GRGT1994
1,034
  • Jan 16, 2006
Given the off/on power difference in the vibration, I would think along the line of other's here - that it probably is an imbalance in the powertrain.
But, one of the most common culprits for vibrations at speed is - tire imbalance. So if I were you, I'd start there. Take it down to the local tire discounter (discount tire by me), and have them balance all 4 tires. It will cost you like $15, and take about 20 minutes.
I had an Exploder that had vibration issues on brake from highway speed. I thought for sure it was the rotors warping. Right around that time, I had to get some new tires. And when they went on, the vibration miraculously went away.
BlackVert
5,589
9
98
Bethesda, MD
Jan 16, 2006
  • Jan 16, 2006
this is stangnet.com, not axels.com
seriously, my shifter handle vibrates some of the time too, but most of the time it doesn't
it doesn't seem to be speed or rpm related.
OrangeMustangGt
1,976
Cape Cod, MA
Jan 16, 2006
  • Jan 16, 2006
my car does that exact same thing, and always has. It pisses me off. Ive replaced all my tires/rims, Rebuilt rear end, and rebuilt my t-5. This leads me to the last thing....the driveshaft, and ive replaced the u-joints twice. My next question is, Can a driveshaft be rebalanced?
bill302
2,131
alabama,gadsden
Jan 16, 2006
#10
  • Jan 16, 2006
  • #10
axle housing
Guero
2,148
Jan 16, 2006
#11
  • Jan 16, 2006
  • #11
so the driveshaft is the axle? im no mechanic.lol. some words i just dont understand.lol
CManT1914
3,172
Killeen, Texas
Jan 16, 2006
#12
  • Jan 16, 2006
  • #12
No, the driveshaft is the piece between the transmission (you know what that is right?) and the rear-end case. Then it forms a "T" and the axles are the top part of the "T", the parts between the rear wheels.
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 16, 2006
#13
  • Jan 16, 2006
  • #13
supposedly the aluminum driveshafts from ford racing are better balanced than the stockers, that seems to help with gear changes and other driveline vibrations. too bad the price on those things went thru the roof.
HISSIN50
34
129
Jan 16, 2006
#14
  • Jan 16, 2006
  • #14
The factory DS's are loosely balanced with other driveline pieces (albeit crudely) at the factory.
One can hit a driveline shop and have them dynamically balance the DS. It is kinda cool since they balance it on the car (so the trans and rear end are figured into the balance).
One can also have the DS alone statically balanced.
Guero
2,148
Jan 16, 2006
#15
  • Jan 16, 2006
  • #15
Driveshaft long piece that turns, right. are the axles expensive? Im lost. Sorry guts its just one of those days that i cant seem to figure out what im doing lol
CManT1914
3,172
Killeen, Texas
Jan 17, 2006
#16
  • Jan 17, 2006
  • #16
That's the right piece. I don't know how much axles are, I've never priced them out.
Guero
2,148
Jan 21, 2006
#17
  • Jan 21, 2006
  • #17
i finally took it the mechanic, he said it might be the fuel injecters. is that even possible?
Highoutput5.0
17
RI
Jan 21, 2006
#18
  • Jan 21, 2006
  • #18
i had the same type of vibration....so i put it up on a lift and got the car up to 100 in 5th gear and saw my driveshaft was shaking/vibrating/way out of balance and possibly warped....new alum driveshaft comes in on monday
Guero
2,148
Jan 21, 2006
#19
  • Jan 21, 2006
  • #19
how much, might as well get one cuz it pisses me of everytime i drive the stang
CManT1914
3,172
Killeen, Texas
Jan 21, 2006
#20
  • Jan 21, 2006
  • #20
Fuel injectors causing a vibration? He's smoking some good stuff!
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
