I installed stage 2 crower cams and the heavy springs they suggest with titainium keepers. Under low load (30 on the dyno) with very slight throttle, the valves start missing on both banks and if i don't give it more throttle, it will cause camshaft sensors to miss and throw error codes all over the place. My dyno tuner (John from Horsepower Ranch.com) said that it is caused from to heavy of valve spring and at low oil pressure, some of the valves will not open. I agree he is correct. The car dynoed at 303 rwhp and when i don't let it get low oil pressure, it runs great. My question: has anyone else had this problem? I think I can use retainers that are higher, or possibly run heavier oil??? By the way this is an 06 mustang gt 4.6l 3v C & L cold air, Diablo preditor tune, 4:10 gears, aluminum driveline, manual trans.
